Unhandled exception when printing float using chprintf
bvanheu
Post by bvanheu »
I am using ChibiOS 2.6.0 on a stm32f4-discovery board using gcc-4.7.2.
I'm trying to print a float using chprintf function, but for an unknown reason, it throws an unhandled_exception.
What i've done:
config/chconf.h
#define CORTEX_USE_FPU                  TRUE
Makefile
UDEFS = -DCHPRINTF_USE_FLOAT=TRUE
ifeq ($(USE_FPU),)
  USE_FPU = yes
endif
src/main.c
int main(void) {
   chprintf(&SDU1, "%f\r\n", 0.1);
   return 0;
But then, it crashes.
I manage to find where, it's in chprintf(), when it tries to call va_arg() in order to pop float/double arguments from the stack:
Partial disassembly of chprintf
gdb> disassemble chprintf
   0x0800488c <+492>:   f7 d1   bne.n   0x800487e <chprintf+478>
   0x0800488e <+494>:   1c e7   b.n     0x80046ca <chprintf+42>
   0x08004890 <+496>:   04 9b   ldr     r3, [sp, #16]
   0x08004892 <+498>:   03 f1 08 02     add.w   r2, r3, #8
   0x08004896 <+502>:   93 e8 03 00     ldmia.w r3, {r0, r1}
   0x0800489a <+506>:   04 92   str     r2, [sp, #16]
   0x0800489c <+508>:   fc f7 58 f9     bl      0x8000b50 <__truncdfsf2>
   0x080048a0 <+512>:   05 90   str     r0, [sp, #20]
   0x080048a2 <+514>:   dd ed 05 7a     vldr    s15, [sp, #20]
The second instruction in the call to __truncdfsf2 makes the uC crash.
Partial disassembly of __truncdfsf2
gdb> disassemble __truncdfsf2
   0x08000b50 <+0>:     78 47 c0 46                     ; <UNDEFINED> instruction: 0x46c04778
   0x08000b54 <+4>:     80 20 a0 e1     lsl     r2, r0, #1
   0x08000b58 <+8>:     07 32 52 e2     subs    r3, r2, #1879048192     ; 0x70000000
   0x08000b5c <+12>:    02 c6 53 22     subscs  r12, r3, #2097152       ; 0x200000
   0x08000b60 <+16>:    7f c5 7c 22     rsbscs  r12, r12, #532676608    ; 0x1fc00000
When the uC executes lsl r2, r0, #1, it crashes (unhandled_exception).
Just before the exception is thrown.
gdb> stepi
0x08000b54 in __truncdfsf2 ()
gdb> i r
r0             0xa0000000       -1610612736
r1             0x3ff19999       1072798105
r2             0x200007f8       536872952
r3             0x200007f0       536872944
r4             0x0      0
r5             0x20     32
r6             0x80052c2        134238914
r7             0x0      0
r8             0x20000e5c       536874588
r9             0x0      0
r10            0x200007a8       536872872
r11            0x0      0
r12            0x1      1
sp             0x20000790       0x20000790
lr             0x80048a1        134236321
pc             0x8000b54        0x8000b54 <__truncdfsf2+4>
xpsr           0x80000000       -2147483648
msp            0x20000400       0x20000400
psp            0x20000790       0x20000790
control        0x6      6 '\006'
faultmask      0x0      0 '\000'
basepri        0x0      0 '\000'
primask        0x0      0 '\000'
Exception...
gdb> stepi
_unhandled_exception () at ../chibios/os/ports/GCC/ARMCMx/STM32F4xx/vectors.c:215
215     void _unhandled_exception(void) {
Any idea why?
I didn't try another gcc version, maybe i should, although i don't see why a lsl should fail... Maybe gdb is not disassembling correctly the instruction?
Re: Unhandled exception when printing float using chprintf
Try to use float constants (0.1d), this way there is no need for truncation. This problem is related to the compiler, try to get the newest from here: https://launchpad.net/gcc-arm-embedded
bvanheu
Post by bvanheu »
Thanks Giovanni!
Although i'm not using Ubuntu, i tried with the last version of GCC (4.8.1) and it worked out of the box... sorry for bothering you.
For future reference on Archlinux, try using thoses packages:
