pito
Posts: 199 Joined: Sun Nov 06, 2011 3:54 pm
Post
by pito » Sun Oct 06, 2013 12:16 pm
Thread [1] (Suspended: Signal 'SIGINT' received. Description: Interrupt.) 5 chSysHalt() core_cmFunc.h:342 0x08001018 4 i2c_lld_set_clock() i2c_lld.c:188 0x08001018 3 i2c_lld_start() i2c_lld.c:629 0x08001018 2 i2cStart() i2c.c:105 0x08001018 1 main() main.c:253 0x08001018 at
osalDbgAssert((STM32_PCLK1 % (clock_speed * 25)) == 0, "PCLK1 must be divided without remainder");with
static const I2CConfig i2cfg1 = { OPMODE_I2C, 400000, FAST_DUTY_CYCLE_16_9 }@24MHz clock
With:
static const I2CConfig i2cfg1 = { OPMODE_I2C, 400000, FAST_DUTY_CYCLE_2 }I get always:
Thread [1] (Suspended: Signal 'SIGINT' received. Description: Interrupt.) 7 chSysHalt() core_cmFunc.h:342 0x08002dfc 6 _dbg_check_lock() chdebug.c:119 0x08002dfc 5 chSysLock() chsys.h:290 0x0800322c 4 i2c_lld_master_transmit_timeout() osal.h:377 0x0800322c 3 i2cMasterTransmitTimeout() i2c.c:189 0x080009ca 2 RTC_PCF8563_isrunning() chTinyRTC8563.c:165 0x080009ca 1 main() main.c:260 0x080009ca
Posts: 14892 Joined: Wed May 27, 2009 8:48 am
Has thanked: 1202 times
Been thanked: 996 times
Post
by Giovanni » Sun Oct 06, 2013 5:02 pm
I don't see errors, you cannot select that specific combination of parameters, you have to respect constraints when specifying the working parameters. See the documentation of the I2C CCR register. Giovanni
pito
Post
by pito » Sun Oct 06, 2013 5:46 pm
I run with
static const I2CConfig i2cfg1 = { OPMODE_I2C, 400000, FAST_DUTY_CYCLE_16_9 }and 40MHz clock my code fine under trunk.
The same with 3.0 (and w/ the changes we discussed earlier) stops. So there must be something different, I do not see on the third glance
I see a new parameter
there. Maybe something related to?
Post
by Giovanni » Sun Oct 06, 2013 6:09 pm
Nope, that is unrelated. Probably you just run without assertions enabled on trunk code, that part of the code didn't change at all. Giovanni
pito
Post
by pito » Sun Oct 06, 2013 6:32 pm
It hangs on
RTC_PCF8563_status = i2cMasterTransmitTimeout(&I2CD1, PCF8563_ADDRESS, txbuf, 1, rxbuf, 9, TMO);
Post
by Giovanni » Sun Oct 06, 2013 6:41 pm
Hangs, how? halt, exception, assertion, simply no return? more info would help, I have no HW to test this driver right now. Giovanni
pito
Post
by pito » Sun Oct 06, 2013 9:11 pm
As indicated above:
Thread [1] (Suspended: Signal 'SIGINT' received. Description: Interrupt.) 7 chSysHalt() core_cmFunc.h:342 0x08002e1c 6 _dbg_check_lock() chdebug.c:119 0x08002e1c 5 chSysLock() chsys.h:290 0x0800324c 4 i2c_lld_master_transmit_timeout() osal.h:377 0x0800324c 3 i2cMasterTransmitTimeout() i2c.c:189 0x080009dc 2 RTC_PCF8563_isrunning() chTinyRTC8563.c:165 0x080009dc 1 main() main.c:263 0x080009dc Code: Select all
uint8_t RTC_PCF8563_isrunning(void) { uint8_t rxbuf[RTC_PCF8563_RX_DEPTH]; uint8_t txbuf[1]; txbuf[0]= 0x00; i2cAcquireBus(&I2CD1); >>> RTC_PCF8563_status = i2cMasterTransmitTimeout(&I2CD1, PCF8563_ADDRESS, txbuf, 1, rxbuf, 9, TMO); i2cReleaseBus(&I2CD1); if (RTC_PCF8563_status==RDY_OK) return TRUE; else return FALSE; }TMO is: #define TMO MS2ST(20)
pito
Post
by pito » Mon Oct 07, 2013 8:44 am
In RT-STMF100-DISCOVERY there is probably wrong def
What I do not understand yet is my compiled code under 3.0 is 5kB smaller than with trunk..
3.0: text data bss dec hex filename 14384 428 4528 19340 4b8c build/ch.elf trunk: text data bss dec hex filename 19492 356 4416 24264 5ec8 build/ch.elfThe mcuconf, cbconf, halconf, Makefile almost identical (plus minus changes with 3.0).
Post
by Giovanni » Mon Oct 07, 2013 9:56 am
Probably because LTO is now enabled by default. I will fix the makefiles but it should not affect anything. Giovanni
pito
Post
by pito » Mon Oct 07, 2013 10:56 am
LTO disabled:
text data bss dec hex filename 17364 428 4528 22320 5730 build/ch.elf2kB less, do I miss something there?
Still hangs on the I2C..
I removed the I2C stuff, printing some adc values and systime, ( with spi, adc, and pwm chunks from demos) in a loop. It does few loops, prints, then stops at 80msec with unhandled exception.. Probably there is more changes as I am aware..
