You mean an oscilloscope? No, I don't have one unfortunately. I don't use PALs anymore, and here's my whole code (it's a bit messy)
ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
2011,2012 Giovanni Di Sirio.
This file is part of ChibiOS/RT.
ChibiOS/RT is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 3 of the License, or
(at your option) any later version.
ChibiOS/RT is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "ch.h"
#include "test.h"
#include "spi.h"
#include "i2c.h"
#include "usbcfg.h"
#include "chprintf.h"
#include "shell.h"
#include "chthreads.h"
// testing rtc
#include "chrtclib.h"
// FIXME :: awaiting fix from the ChibiOS/RT team
#define usb_lld_connect_bus(usbp)
#define usb_lld_disconnect_bus(usbp)
// This didn't work =(^U IT'S ALIVE! ALIVE!!!
#define USB_GPIO_PORT GPIOA
#define USBDM_BIT GPIOA_USB_DM
#define USBDP_BIT GPIOA_USB_DP
void usb_lld_disconnect_bus(USBDriver *usbp)
(void) usbp;
palClearPort(USB_GPIO_PORT, (1<<USBDM_BIT) | (1<<USBDP_BIT));
palSetPadMode(USB_GPIO_PORT, USBDM_BIT, PAL_MODE_OUTPUT_PUSHPULL);
palSetPadMode(USB_GPIO_PORT, USBDP_BIT, PAL_MODE_OUTPUT_PUSHPULL);
void usb_lld_connect_bus(USBDriver *usbp)
(void) usbp;
palSetPadMode(USB_GPIO_PORT, USBDM_BIT, PAL_MODE_ALTERNATE(14));
palSetPadMode(USB_GPIO_PORT, USBDP_BIT, PAL_MODE_ALTERNATE(14));
/* Virtual serial port over USB.*/
SerialUSBDriver SDU1;
static float mdps_per_digit = 8.75;
uint8_t schema = 0;
#define MAXSCH 2
static const SPIConfig spi1cfg = {
NULL,
/* HW dependent part.*/
GPIOE,
GPIOE_SPI1_CS,
SPI_CR1_BR_0 | SPI_CR1_BR_1 | SPI_CR1_CPOL | SPI_CR1_CPHA,
0
static const I2CConfig i2cconfig = {
0x00902025, //voodoo magic
0,
0
static uint8_t readByteSPI(uint8_t reg)
char txbuf[2] = {0x80 | reg, 0xFF};
char rxbuf[2];
spiSelect(&SPID1);
spiExchange(&SPID1, 2, txbuf, rxbuf);
spiUnselect(&SPID1);
return rxbuf[1];
static uint8_t writeByteSPI(uint8_t reg, uint8_t val)
char txbuf[2] = {reg, val};
char rxbuf[2];
spiSelect(&SPID1);
return rxbuf[1];
static uint8_t readByteI2C(uint8_t addr, uint8_t reg)
uint8_t data;
i2cAcquireBus(&I2CD1);
(void)i2cMasterTransmitTimeout(&I2CD1, addr, ®, 1, &data, 1, TIME_INFINITE);
i2cReleaseBus(&I2CD1);
return data;
static void writeByteI2C(uint8_t addr, uint8_t reg, uint8_t val)
uint8_t cmd[] = {reg, val};
(void)i2cMasterTransmitTimeout(&I2CD1, addr, cmd, 2, NULL, 0, TIME_INFINITE);
static void initGyro(void)
/* see the L3GD20 Datasheet */
writeByteSPI(0x20, 0xcF);
static void initAccel(void)
// Highest speed, enable all axes
writeByteI2C(0x19, 0x20, 0x97);
static void initMag(void)
// Highest speed
writeByteI2C(0x1E, 0x00, 0x1C);
writeByteI2C(0x1E, 0x02, 0x00);
static uint8_t readGyro(float* data)
/* read from L3GD20 registers and assemble data */
/* 0xc0 sets read and address increment */
char txbuf[8] = {0xc0 | 0x27, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
char rxbuf[8];
spiSelect(&SPID1);
spiExchange(&SPID1, 8, txbuf, rxbuf);
if (rxbuf[1] & 0x7) {
int16_t val_x = (rxbuf[3] << 8) | rxbuf[2];
int16_t val_y = (rxbuf[5] << 8) | rxbuf[4];
int16_t val_z = (rxbuf[7] << 8) | rxbuf[6];
data[0] = (((float)val_x) * mdps_per_digit)/1000.0;
data[1] = (((float)val_y) * mdps_per_digit)/1000.0;
data[2] = (((float)val_z) * mdps_per_digit)/1000.0;
return 1;
return 0;
static uint8_t readAccel(float* data)
// setting MSB makes it increment the address for a multiple byte read
uint8_t start_reg = 0x27 | 0x80;
uint8_t out[7];
msg_t f = i2cMasterTransmitTimeout(&I2CD1, 0x19, &start_reg, 1, out, 7, TIME_INFINITE);
(void)f;
if (out[0] & 0x8) {
int16_t val_x = (out[2] << 8) | out[1];
int16_t val_y = (out[4] << 8) | out[3];
int16_t val_z = (out[6] << 8) | out[5];
// Accel scale is +- 2.0g
data[0] = ((float)val_x)*(4.0/(65535.0))*9.81;
data[1] = ((float)val_y)*(4.0/(65535.0))*9.81;
data[2] = ((float)val_z)*(4.0/(65535.0))*9.81;
return 1;
return 0;
static uint8_t readMag(float* data)
uint8_t start_reg = 0x03;
uint8_t out[7];
msg_t f = i2cMasterTransmitTimeout(&I2CD1, 0x1E, &start_reg, 1, out, 7, TIME_INFINITE);
(void)f;
//out[6] doesn't seem to reflect actual new data, so just push out every time
int16_t val_x = (out[0] << 8) | out[1];
int16_t val_z = (out[2] << 8) | out[3];
int16_t val_y = (out[4] << 8) | out[5];
data[0] = ((float)val_x)*1.22;
data[1] = ((float)val_y)*1.22;
data[2] = ((float)val_z)*1.22;
return 1;
#define SHELL_WA_SIZE THD_WA_SIZE(1024)
static void cmd_test(BaseSequentialStream *chp, int argc, char *argv[]) {
(void) argc;
(void) argv;
chprintf(chp, "ChibiOS test suite\r\n");
TestThread(chp);
static void cmd_gyrodata(BaseSequentialStream *chp, int argc, char *argv[]) {
float gyrodata[3];
uint32_t times = 5;
uint32_t delay = 200;
if (argc >= 1) {
times = atoi(argv[0]);
if (argc >= 2) {
delay = atoi(argv[1]);
uint32_t i = 0;
chprintf(chp, " Number 1\t Number 2\t Number 3\t #\r\n");
for (i = 0; i < times; i++) {
if (readGyro(gyrodata)) {
chprintf(chp, " %f\t %f\t %f\t %d\r\n", gyrodata[0], gyrodata[1], gyrodata[2], i);
chThdSleepMilliseconds(delay);
static void cmd_magdata(BaseSequentialStream *chp, int argc, char *argv[]) {
float magdata[3];
uint32_t times = 5;
if (argc >= 1) {
if (argc >= 2) {
uint32_t i = 0;
if (readMag(magdata)) {
chprintf(chp, " %f\t %f\t %f\t %d\r\n", magdata[0], magdata[1], magdata[2], i);
static void cmd_adjust(BaseSequentialStream *chp, int argc, char *argv[]) {
float gyrodata[2][3];
(void) argc;
(void) argv;
chprintf(chp, "Adjust the motorcycle vertically and press the User button\r\n");
while (!palReadPad(GPIOA, GPIOA_BUTTON)) { }
if (!readGyro(gyrodata[0])) {
chprintf(chp, "Error getting gyrodata!\r\n");
return;
else {
chprintf(chp, "Got gyrodata for the 1st time!\r\n");
chThdSleepMilliseconds(5000);
chprintf(chp, "Now place it on the side stand and press the button again\r\n");
if (!readGyro(gyrodata[1])) {
return;
} else {
chprintf(chp, "Got gyrodata for the 2nd time!\r\n");
chprintf(chp, "Got your gyrodata successfully\r\n");
uint8_t i = 0;
for (i = 0; i < 2; i++) {
chprintf(chp, "%d\t %f\t %f\t %f\r\n", i, gyrodata[i][0], gyrodata[i][1], gyrodata[i][2]);
static void cmd_time(BaseSequentialStream *chp, int argc, char *argv[]) {
if (argc == 0) {
time_t unixTime = rtcGetTimeUnixSec(&RTCD1);
struct tm ts = *gmtime(&unixTime);
chprintf(chp, "current rtc time: %d\r\n", unixTime);
chprintf(chp, "which is %d-%02d-%02d %02d:%02d:%02d UTC\r\n", (1900+ts.tm_year), (1+ts.tm_mon), ts.tm_mday, ts.tm_hour, ts.tm_min, ts.tm_sec);
} else if (argc == 1) {
time_t newtime = atoi(argv[0]);
rtcSetTimeUnixSec(&RTCD1, newtime);
struct tm ts = *gmtime(&newtime);
chprintf(chp, "New time is: %d\r\n", newtime);
static void cmd_mem(BaseSequentialStream *chp, int argc, char *argv[]) {
// size_t n, size;
(void) argv;
(void) argc;
// n = chHeapStatus(&size);
chprintf(chp, "core free memory : %u bytes\r\n", chCoreStatus());
// chprintf(chp, "heap fragments : %u\r\n", n);
// chprintf(chp, "heap free total : %u bytes\r\n", size);
static void cmd_reboot(BaseSequentialStream *chp, int argc, char *argv[]) {
(void) argc;
(void) argv;
chprintf(chp, "Rebooting...\r\n");
chThdSleepMilliseconds(100);
NVIC_SystemReset();
static void cmd_schema(BaseSequentialStream *chp, int argc, char *argv[]) {
if (argc == 0) {
chprintf(chp, "Current blink schema is %d\r\n", schema);
} else {
uint8_t newsch = atoi(argv[0]);
if (newsch > MAXSCH) {
newsch = schema;
schema = newsch;
chprintf(chp, "Set blinking schema to %d\r\n", schema);
static const ShellCommand shCmds[] = {
{"test", cmd_test},
{"gyrodata", cmd_gyrodata},
{"magdata", cmd_magdata},
{"adjust", cmd_adjust},
{"schema", cmd_schema},
{"time", cmd_time},
{"free", cmd_mem},
{"reboot", cmd_reboot},
{NULL, NULL}
static const ShellConfig shCfg = {
(BaseSequentialStream *)&SDU1,
shCmds
static WORKING_AREA(waThreadButton, 128);
static msg_t ThreadButton(void *arg) {
(void) arg;
chRegSetThreadName("button");
while (TRUE) {
if (schema == MAXSCH) {
schema = 0;
} else {
schema++;
chprintf((BaseSequentialStream *)&SDU1, "Schema set to %d\r\n", schema);
chThdSleepMilliseconds(500);
return 0; // nevar forget
static WORKING_AREA(waThreadBlink, 128);
static msg_t ThreadBlink(void *arg) {
(void) arg;
uint8_t i = GPIOE_LED4_BLUE;
while (TRUE) {
if (schema == 0) { // all LEDs on, then off in the other direction
if (i > GPIOE_LED6_GREEN + GPIOE_LED4_BLUE) {
if (i <= GPIOE_LED6_GREEN) {
palSetPad(GPIOE, i);
else {
palClearPad(GPIOE, 31-i);
i++;
else if (schema == 1) { // All LEDs on, then off in same direction
if (i > GPIOE_LED6_GREEN) {
palTogglePad(GPIOE, i);
i++;
else if (schema == 2) { // LED snake, length = 3
if (i+3 <= GPIOE_LED6_GREEN) {
palSetPad(GPIOE, i+3);
else {
palSetPad(GPIOE, i-5);
palClearPad(GPIOE, i);
i++;
else if (schema == 3) {
chThdSleepMilliseconds(125);
return 0; // never returns
static PWMConfig pwmcfg = {
10000,
10000,
NULL,
{PWM_OUTPUT_ACTIVE_HIGH, NULL},
0
int main(void) {
Thread *sh = NULL;
shellInit();
chThdSleepMilliseconds(1000);
sduObjectInit(&SDU1);
sduStart(&SDU1, &serusbcfg);
spiStart(&SPID1, &spi1cfg);
i2cStart(&I2CD1, &i2cconfig);
initGyro();
initAccel();
initMag();
pwmStart(&PWMD1, &pwmcfg);
pwmEnableChannel(&PWMD1, 0, 5000);
pwmEnableChannel(&PWMD1, 1, 5000);
pwmEnableChannel(&PWMD1, 2, 5000);
pwmEnableChannel(&PWMD1, 3, 5000);
uint8_t i = 8;
for (i = 8; i < 15; i++) {
palSetPadMode(GPIOE, i, PAL_MODE_ALTERNATE(2));
//chThdCreateStatic(waThreadBlink, sizeof(waThreadBlink), NORMALPRIO, ThreadBlink, NULL);
//chThdCreateStatic(waThreadButton, sizeof(waThreadButton), NORMALPRIO, ThreadButton, NULL);
while (TRUE) {
if (!sh) {
sh = shellCreate(&shCfg, SHELL_WA_SIZE, NORMALPRIO);
else if (chThdTerminated(sh)) {
chThdRelease(sh);
sh = NULL;
float gyroData[3];
float accelData[3];
float magData[3];
if (readGyro(gyroData) && readAccel(accelData) && readMag(magData)) {
chprintf((BaseSequentialStream *)&SDU1, "%f %f %f ", gyroData[0], gyroData[1], gyroData[2]);
chprintf((BaseSequentialStream *)&SDU1, "%f %f %f ", accelData[0], accelData[1], accelData[2]);
chprintf((BaseSequentialStream *)&SDU1, "%f %f %f\n", magData[0], magData[1], magData[2]);
return 0; // never returns, lol
You might find the tail of the code (int main() and a little bit above) useful.
