ChibiOS config can be found here: https://github.com/pavel-kirienko/px4es ... s/chconf.h, https://github.com/pavel-kirienko/px4es ... /halconf.h.
There are two fast interrupts that shall be processed with (virtually) zero latency: ADC1 and TIM2.
Their handlers: https://github.com/pavel-kirienko/px4es ... mer.c#L105 and https://github.com/pavel-kirienko/px4es ... _adc.c#L50.
As can be seen, no OS API are used from these interrupt handlers.
Other interrupt sources are UART1 (ChibiOS driver, low priority) and the ChibiOS core itself, nothing else.
The problem is that the memory got corrupted only if the fast IRQ priority exceeds CORTEX_MAX_KERNEL_PRIORITY (i.e. if the priority equals 0 or 1). It appears as stack overflow of the main thread (no other threads ever created); checking the system state in the debugger I can see that the otp structure got spoiled:
otp Thread * 0x20001120
p_next Thread * 0x20001228
p_prev Thread * 0x1
p_prio tprio_t 1
p_ctx struct context {...}
p_newer Thread * 0x20001138
p_older Thread * 0x0
p_name const char * 0x0
p_stklimit stkalign_t * 0x0
*p_stklimit stkalign_t
p_state tstate_t 72 'H'
p_flags tmode_t 17 '\\021'
p_preempt tslices_t 0 '\\000'
p_time volatile systime_t 134239287
p_u union {...} {...}
p_waiting ThreadsList {...}
p_epending eventmask_t 536875352
p_mtxlist Mutex * 0x800ca71
p_realprio tprio_t 536875360
For reference, there is the same structure dumped during normal operation:
p_prev Thread * 0x20001228
p_prio tprio_t 1
p_newer Thread * 0x20001228
p_older Thread * 0x200011d0
p_name const char * 0x800d070 "idle"
p_stklimit stkalign_t * 0x200011d0
p_state tstate_t 1 '\\001'
p_preempt tslices_t 20 '\\024'
p_time volatile systime_t 536875296
p_epending eventmask_t 536875560
p_mtxlist Mutex * 0x20001228
p_realprio tprio_t 0
The stack overflow panic is always invoked from the UART1 interrupt (remember this is the only low priority interrupt source besides the core IRQs), so that makes me think that there is something wrong with IRQ preemption. Note that I checked both main stack and the process stack in the debugger after the failure, and they both appear to be not overflowed (default fill pattern 0x55 can be seen). Regardless, I even tried to increase both stacks up to 4kb each, didn't help.
What am I doing wrong?
Thanks!
