STM32F407 + LWIP + UDP: receiving is stopped after 9packets
Posted: Fri Nov 29, 2013 10:24 am
by Adam
Hi!
I´m using mcu STM32F407VGT6 with ChibiOS + LWIP stack. I trying to receive broadcast packets.
I´m using blocking function netconn_recv. After reset, I can receive exactly first 9 incomming packets, then receiving is stopped a fuction still waits for incomming packets. I confident, that packets are comming (checked by wireshark).
Here is my code of receiving thread:
WORKING_AREA(waThread_NetworkCTRL, 2048);
msg_t Thread_NetworkCTRL(void *arg) {
  LWIP_UNUSED_ARG(arg);
  chRegSetThreadName("NetworkCtrl");
  static struct netconn *conn_ctrl_recv;
  static struct netbuf *recv_buf;
  err_t err;
  conn_ctrl_recv = netconn_new(NETCONN_UDP); // create new connection
  err = netconn_bind(conn_ctrl_recv, IP_ADDR_ANY, port_ctrl); // bind the connection
  while(1){
    // create buffer
    recv_buf = netbuf_new();
    //receive
    err = netconn_recv(conn_ctrl_recv, &recv_buf);
    if(err == ERR_OK){
      printMsg("Incomming packet!\n");
    netbuf_free(recv_buf);
    netbuf_delete(recv_buf);
  netconn_disconnect(conn_ctrl_recv);
  return (msg_t)0;
And here is simple python script for generating broadcast packets:
import socket
import time
UDP_IP = "192.168.10.255"
UDP_PORT = 33001
MESSAGE = "ETC:NOTIFY;"
MESSAGE.encode ('utf-8')
UDP_IP.encode ('utf-8')
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) # UDP
while(1):
  sock.sendto(bytes(MESSAGE, "utf-8"), (UDP_IP, UDP_PORT))
  time.sleep(1) # delays for 5 seconds
Do you know how to solve my problem? Debug is "ON", but cant catch anything.
Thank you!
Adam
Re: STM32F407 + LWIP + UDP: receiving is stopped after 9pack
Posted: Fri Nov 29, 2013 12:06 pm
What is the state of the system after the 9 packets? crashed or threads continue running?
Posted: Fri Nov 29, 2013 5:22 pm
by Adam
I dont have the device with me at this moment, so i cant tell you state of thread or chibios exactly. But answer for your question is: the device is not crashing, after 9 packets everything works except receiving next packets. The behavior of device i can describe this way: after receive nineth packet, program go to the function netconn_recv() and waits for 10th packet, but never come. However 10th packet is already send from transmitter. When i pause debugger, MCU is paused in "idle thread".
Thank you, Giovanni.
Adam
Posted: Fri Nov 29, 2013 5:33 pm
There are several entities involved:
1) Hardware.
2) MAC driver.
3) lwIP interface layer.
4) lwip thread.
5) lwIP.
6) Application.
We need to check from 1 to 6. First, after the 9th packet, does the MAC driver continue to receive frames (a breakpoint in the ISR could tell us this). Then does the lwip thread continue to serve those frames and send them to lwIP (again a breakpoint in the thread could reveal this) and so on.
You need to understand where the flow stops. I never used lwIP much so I can't help at that level.
Also, do the debugging at -O0 optimization and enable the debug options in chconf.h, something could get caught by an assertion.
Posted: Mon Dec 02, 2013 9:04 am
by Adam
debug is already turned on, as well compiler optimize -O0.
Nothing is catched. When I pause the device, the state of receiving thread after 9th packets is WTSEM. I found part of code, where thread is waiting: its in function
msg_t chSemWaitTimeoutS(Semaphore *sp, systime_t time)
here is trace log of called functions:
netconn_recv_data(struct netconn *conn, void **new_buf);
sys_arch_mbox_fetch(&conn->recvmbox, &buf, 0);
chMBFetchS(*mbox, (msg_t *)msg, tmo)
chSemWaitTimeoutS(&mbp->mb_fullsem, time); <-- here is waiting.
Where can I find ISR´s of MACdriver?
Posted: Mon Dec 02, 2013 9:37 am
In ./os/hal/platforms/stm32/mac_lld.c, there is a specific section in the file for ISRs.
Posted: Mon Dec 02, 2013 10:16 am
by Adam
It seems the problem is solved! The problem was in a bad use netbuf buffer.
This is WRONG:
This is CORRECT:
Conclusion:
Dont create new netbuf buffer before use netconn_recv()!
Giovanni, thank you for your help!
Adam
