Page 1 of 2
Need explanations about Floating Point Unit
Posted: Mon Dec 09, 2013 12:45 pm
by Fede
Hi all,
I would like to use the fpu on stm32f4 Discovery board, to do that I have to set (USE_FPU = yes) in the makefile and that's all?
so whether I write: float x = 2.0f * 5.0f; this will be calculated with fpu?
I noticed these two rows in the bottom of makefile:
ifeq ($(USE_FPU),yes)
USE_OPT += -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -fsingle-precision-constant
DDEFS += -DCORTEX_USE_FPU=TRUE
It means that FPU is in fact a software fpu? if is true, how can i use hardware fpu? -mfloat-abi=hard?
I'm confused... sorry
Thank you in advance
PS: ( I use gcc with -lm on ubuntu )
Re: Need explanations about Floating Point Unit
Posted: Mon Dec 09, 2013 1:30 pm
The Cortex-M4 FPU only handles single precision floats (32 bits), double precision is handled in software by libraries.
Fede wrote:so whether I write: float x = 2.0f * 5.0f; this will be calculated with fpu?
No, it is double precision and the multiplication would be performed at compile time anyway being a constant expression.
Posted: Mon Dec 09, 2013 2:25 pm
by Fede
Thanks Giovanni, but i can't understand why it is a double precision...
According to:
http://www.st.com/st-web-ui/static/active/jp/resource/technical/document/application_note/DM00047230.pdf3.5.1 Arithmetic instructions [pag. 14]
The FPU offers arithmetic instructions for:
â— Absolute value (1 cycle)
â— Negate of a float or of multiple floats (1 cycle)
â— Addition (1 cycle)
â— Subtraction (1 cycle)
â— Multiply, multiply accumulate/subtract, multiply accumulate/subtract then negate (3 cycles)
â— Divide (14 cycles)
â— Square root (14 cycles)
All the MAC operations can be standard or fused (rounding done at the end of the MAC for a
better accuracy).
3.5.2 FPU compare & convert instructions
The FPU has compare instructions (1 cycle) and a convert instruction (1 cycle).
Conversion can be done between integer, fixed point, half precision and float
float x=1.2f;
float y=1.3f;
float z=x*y; // (3 cycles) ?
If it is wrong yet, what is the correct way?
Posted: Mon Dec 09, 2013 2:39 pm
You should look at the generated code. The compiler is smart enough to understand those lines are a constant expression even if you declare 3 variables.
Posted: Tue Dec 10, 2013 4:51 pm
by pito
The FPU inside STM32F4 is a single precision fpu (32bit). Double precision calculations (64bit float number) are provided in software.
To avoid the compiler optimizes the calculation off, you may try:
// prints out a double precision number in hex
void print64x( double x ) {
const char* p;
int j;
p = (char *) &x;
for( j=0; j< sizeof(x); j++) {
printf("%02X", p[(sizeof(x)-1)-j]&0xFF);
// prints out a single precision number in hex
void print32x( float x ) {
const char* p;
int j;
p = (char *) &x;
volatile double x;
volatile double y;
volatile double z;
for (int i = 0; i<=10; i++) {
x = 3.1415;
y = x * i;
z = x + y;
printf("z = %f\n", z);
printf("z (single HEX) = "); print32x( z ); printf("\n");
printf("z (double HEX) = "); print64x( z ); printf("\n");
Posted: Thu Dec 12, 2013 4:13 pm
by kenyee
I think what Fede is saying is if he defines all his variables to be the C type "float" instead of "double", will it use the Cortex's single precision FPU?
I'm curious myself though I haven't tried it yet (still waiting on an STM32F429 Discovery board)...
Posted: Thu Dec 12, 2013 5:04 pm
I think you have to use "single" in order to use the FPU.
Posted: Sun Feb 02, 2014 3:54 pm
by pito
I've spent few hours trying to understand the fp in CM4 chibios too..
Still coping with it however. Here is a short demo (STM32F4 Discovery demo based), one may try:
// Simple math test
#include "ch.h"
#include "hal.h"
#include "chprintf.h"
#include <math.h>
#define serial2 (BaseSequentialStream*)&SD2
int main(void) {
sdStart(&SD2, NULL);
palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
while (TRUE) {
volatile float q32, p32;
int i;
systime_t timestart, timeelapsed;
chprintf (serial2, " THIS IS THE START \r\n");
p32 = 3.1415926535897932384626433832795f;
timestart = chTimeNow();
for (i=1;i<=1000;i++) {
// 9 degree
q32 = 9.000f;
// Convert to radians
q32 = q32 * p32 / 180.0f;
// Make the test
q32= asin(acos(atan(tan(cos(sin(q32))))));
// Convert to degree
q32 = q32 * 180.0f / p32;
timeelapsed = chTimeNow() - timestart;
chprintf(serial2, " Elapsed time 1000x : %d millis\r\n", timeelapsed);
chprintf(serial2, " Elapsed time : %f millis\r\n", timeelapsed/1000.0f);
chprintf (serial2, " Result : %f \r\n", q32);
chprintf (serial2, " THIS IS THE END \r\n \r\n");
chThdSleepMilliseconds(100);
I did following int Makefile:
# Enables the use of FPU on Cortex-M4.
# Enable this if you really want to use the STM FWLib.
ifeq ($(USE_FPU),)
USE_FPU = yes
endif
ifeq ($(USE_FWLIB),)
USE_FWLIB = no
endif
# Start of user section
# List all user C define here, like -D_DEBUG=1
UDEFS = -DCHPRINTF_USE_FLOAT=TRUE -DUSE_FPU=TRUE
# List all user libraries here
ULIBS = -lm
It seems to me the FPU is not activated however. Getting results around 114ms with -DUSE_FPU=FALSE and the same with TRUE..
PS: It would be great to have the floating point printf and FPU enabling supported in chconf.h by 2 simple defines, for example..
Posted: Sun Feb 02, 2014 3:58 pm
The FPU handles single floats only, if you use double float the calculation is done in SW. You can see the difference in context switch time, when the FPU is enabled scores are much lower because the overhead.
Posted: Sun Feb 02, 2014 4:05 pm
by pito
Giovanni,
I am using
single precision floating point types (32bit) supported by the FPU.
There is no other way to define a single precision float..
It might be, that there is somewhere a compiler directive defining
the single precision float shall be handled as double, then, of course, the compiler does it in sw (as it will handle the single precision as the double).
-fshort-double
Use the same size for double as for float.
But the source above must be compiled with FPU support when everything is ok.
