USB Bootloader
mobyfab
Has thanked: 21 times
Been thanked: 31 times
USB Bootloader
Post by mobyfab »
Hey,
I just finished writing a USB bootloader and a GUI to operate it. (based on some code from mabl and demos)
You will need to install the provided drivers manually to use it. Only tested on win7 x64 so far, will do linux later on.
https://github.com/mobyfab/ChibiOS-Bootloader
Let me know if it works for you, any feedback is appreciated!
Thanks!
Re: USB Bootloader
This looks very promising!
Good job as always, mobyfab ;)
DEHiCKA
Has thanked: 4 times
Re: USB Bootloader
Post by DEHiCKA »
Fabien, hi! Just flashed your bootloder.
I can connect to the device from GUI, but every commnad results in
"WinUsb_ReadPipe" ERROR_SEM_TIMEOUT 121
New Transfer Thread
***[ bool __thiscall MainWindow::Connect(void) ]***
***[ bool __thiscall QUsb::GetDeviceHandle(struct _GUID,void **) ]***
Device path:  \
***[ bool __thiscall QUsb::GetWinUSBHandle(void *,void **) ]***
***[ bool __thiscall QUsb::GetUSBDeviceSpeed(void *,unsigned char *) ]***
Device speed: 1 (Low speed).
***[ bool __thiscall QUsb::QueryDeviceEndpoints(void *,struct QUsb::PIPE_ID *) ]
Bulk OUT Endpoint index: 0 Pipe type: Bulk Pipe ID: 0x03.
Bulk IN Endpoint index: 1 Pipe type: Bulk Pipe ID: 0x83.
***[ int __thiscall QUsb::read(class QByteArray *,unsigned int) ]***
***[ int __thiscall QUsb::write(class QByteArray *,unsigned int) ]***
Sent 5 / 5 bytes: "AF:EB:A5:05:44"
Then I flashed user_app manually. I've got composite USB and CDC, but bootloader GUI still can't do anything with it.
Shell works on CDC, but no commands are recognized. It always answers "<command> ?"
mobyfab
Re: USB Bootloader
Post by mobyfab »
mhhh seems like it's using the wrong endpoints. should be 0x01 and 0x81, not 0x03 and 0x83.
I will have to hardcode them I guess. Are you sure it's running the bootloader and not the user app?
You need to reset the mcu for the bootloader to not launch the user app. (you can do this with stlink)
You can also send the 0xAB byte to the bulk interface (endpoint 3), it will trigger a reset.
DEHiCKA
Re: USB Bootloader
Post by DEHiCKA »
I've erased flash by st-link and flased bootloader again. Then I flashed user app by GUI, this time it's flashed, but with errors.
New Transfer Thread
Device path:  \
Bulk OUT Endpoint index: 0 Pipe type: Bulk Pipe ID: 0x01.
Bulk IN Endpoint index: 1 Pipe type: Bulk Pipe ID: 0x81.
Received 2 of 2 Bytes: "50:01"
Writing flash
File size 45396
Sent 9 / 9 bytes: "AF:EB:A1:09:54:B1:00:00:49"
Received 2 of 2 Bytes: "50:10"
Erase OK
Writing from "0x0" to "0xb154"
Read 96 Bytes from disk
Sent 105 / 105 bytes: "AF:EB:A3:69:00:00:00:00:00:04:00:20:81:42:00:08:41:43:00:
08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43
:00:08:41:43:00:08:71:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:44:00:08:4
1:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:
08:41:43:00:08:CE"
Received 1 of 1 Bytes: "50"
Sent 105 / 105 bytes: "AF:EB:A3:69:60:00:00:00:41:43:00:08:41:43:00:08:41:43:00:
:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:41:43:00:08:4
08:41:43:00:08:26"
Received 1 of 1 Bytes: "72"
Transfer done
So no USB CDC, not BULK, and reflashing bootloader did not help. I need to manually erase page at 0x08004000 to make bootloader to work again.
mobyfab
Re: USB Bootloader
Post by mobyfab »
I'm fine tuning the delays right now, check the code in an hour. :)
I have just completed the linux version and tested it.
mobyfab
Re: USB Bootloader
Post by mobyfab »
Done, I have updated the drivers and the GUI binary.
You have to reinstall the drivers. (uninstall devices and delete driver, reinstall using new driver files)
I have tested it under windows and linux, it should work fine now :)
mobyfab
Re: USB Bootloader
Post by mobyfab »
This is what the bootloader looks like, it's based on my QStlink2 app. :)
