I wrote code to use the HC-05 serial bluetooth module in ChibiOS projects.
The code is at http://code.google.com/p/chibios-bluetooth/
This is my first ever real-life code contribution and I would like to ask for your comments on it.
Most of the bluetooth-related commands are macros, as we have to send the modul AT commands in AT mode, but in communication mode, it is only a serial port.
For some reason I could not track down, only the first AT command is interpreted by the module (e.g. setting the name), but the others (setting the pin) are not.
A workaround is to reset the module after each at command, but it is not that efficient.
I started to create some documentation, so that the code could be easier to follow. For some reason doxygen simply ignores it.
Do you have any ideas?
Thank you,
Peter
