C++ class::method() as driver callback
Posted: Mon Jan 27, 2014 3:24 pm
by Debbio
I want to encapsulate for example the uart driver inside a protocol communication class :
class protocol{
   UARTDriver  *uart_drv;
   UARTConfig uart_cfg;
 public :
   protocol(....){
    uart_cfg.rxEnd = (  ? cast ? ) protocol::method;
private :
  method(){
What kind of cast is it correct ?
Something like this ? (not really tried)
 typedef void(cb*)(UARTDriver*);
  uart_cfg.rxEnd =  reinterpret_cast<cb>(&protocol::method);
Maybe encapsulation of drivers inside class wouldn't be the best design choice?
Thanks in advance.
Re: C++ class::method() as driver callback
Posted: Mon Jan 27, 2014 4:06 pm
The callbacks are part of the configuration structure usually, I don't think you should put driver and configuration structure in the same class. The reference to the configuration is already present in the driver so it would be a duplication.
Posted: Wed Jan 29, 2014 10:52 am
by Debbio
About casting , this works :
cfg.callback= (void(*)(GPTDriver*))&Protocol::method;
BUT IT IS USELESS , inside the call back you have no reference to your class members, complier won't complain but you cannot use you class::method or your class variable , for me it was not obvious .
You need to pass the reference of your class as argument as chibios does for the driver reference.
/** Uart callback assigned to class method*/
void protocol::method(UARTDriver *d){
 classVariable = value;  /** Not affecting classVariable*/
 classMethod();  /** see the former */
So if you want to use some driver callback my conclusion is that you have to pass data , in this case chars on rx buffer , to the worker thread class with mailbox and so on.
Here some pseudo code , i haven't tried it yet:
void txend(UARTDriver*, uint16_t c){
   chMbPostI(mb, c ); /** and you need to share mailbox with worker thread class*/
class protocol : public BaseStaticThread<256> {
  msg_t main(void){
    while(1){
        chMbFetch(mb,data,timeout);
And what about changing your class internal state synchronously to a driver callback ?
you will need to know the reference of the worker thread or to the class itself , is it the cleanest way ?
 void rxend(GPTDriver* d , uint16_t c){
   classRef->resumeI(msg); /** clean solution ? */
Design suggestions well accepted.
Posted: Fri Jan 31, 2014 9:57 pm
by andyturk
I routinely implement driver callbacks in C++. To do this, I usually derive classes from configuration structs rather than the driver structs. Here's an example:
  class UART : protected UARTConfig {
  protected:
    UARTDriver &uart;
    static void txend1_cb(UARTDriver *u);
    static void txend2_cb(UARTDriver *u);
    static void rxend_cb(UARTDriver *u);
    static void rxchar_cb(UARTDriver *u, uint16_t c);
    static void rxerr_cb(UARTDriver *u, uartflags_t e);
    virtual void txend1() {}
    virtual void txend2() {}
    virtual void rxend() {}
    virtual void rxchar(uint16_t c) {}
    virtual void rxerr(uartflags_t err) {}
  public:
    UART(UARTDriver &u, uint32_t baud = 115200, uartflags_t cr3_flags = 0);
    uartstate_t get_state() const       {return uart.state;}
    void set_baud(uint32_t baud);
    void start();
    void stop();
    void send (void *bytes, size_t len) {uartStartSend    (&uart, len, (uint8_t *) bytes);}
    void sendI(void *bytes, size_t len) {uartStartSendI   (&uart, len, (uint8_t *) bytes);}
    void recv (void *bytes, size_t len) {uartStartReceive (&uart, len, (uint8_t *) bytes);}
    void recvI(void *bytes, size_t len) {uartStartReceiveI(&uart, len, (uint8_t *) bytes);}
The callback implementations look like this:
  void UART::txend1_cb(UARTDriver *d) {
    UART *u = (UART *) d->config;
    u->txend1();
The callback pointers in the config struct are initialized in the constructor:
  UART::UART(UARTDriver &u, uint32_t baud, uint32_t cr3_flags) :
    UARTConfig(),
    uart(u)
    UARTConfig::txend1_cb = &UART::txend1_cb;
    UARTConfig::txend2_cb = &UART::txend2_cb;
    UARTConfig::rxend_cb  = &UART::rxend_cb;
    UARTConfig::rxchar_cb = &UART::rxchar_cb;
    UARTConfig::rxerr_cb  = &UART::rxerr_cb;
    speed = baud;
    cr1 = 0;
    cr2 = 0;
    cr3 = cr3_flags;
