Change gcc optimization level
Posted: Mon Feb 03, 2014 2:04 am
by dhruvin91
Our program has unpredictable behavior on some instances. but if I add a line that should not make a difference program works.
I think this is because of optimization level. It might go away if I change optimization level from 3 to 2.
Does anyone know how to do so?
Thank you.
Re: Change gcc optimization level
Posted: Mon Feb 03, 2014 9:22 am
HI,
Edit the Makefile in the project, the level is 2 by default (and note, you should not have instabilities at any optimization level, you risk to hide the real problem).
Posted: Fri Feb 07, 2014 2:17 am
by dhruvin91
Thanks for the help. Yes you were right. This did not make much difference.
And I still need help. It would be great if I can get help with this.
I have following function
boolean sendCommandCheckAck_fcn(uint8_t *cmd, uint8_t cmdlen, uint16_t timeout) {
uint16_t timer = 0;
uint8_t x;
// write the command
spiwritecommand_fcn(cmd, cmdlen);
// Wait for chip to say its ready!
while (readspistatus_fcn() != PN532_SPI_READY) {
if (timeout != 0) {
timer+=10;
if (timer > timeout)
return FALSE;
delay_ms(10);
ghConsoleprint("h1\n");
// read acknowledgement
if (!spi_readack_fcn()) {
return FALSE;
ghConsoleprint("h2\n");
timer = 0;
x=readspistatus_fcn();
while (x != PN532_SPI_READY) {
if (timeout != 0) {
timer+=10;
return FALSE;
delay_ms(10);
return TRUE; // ack'd command
Here if I change following code
to following
The function would not work. With first code, STM32 detects PN532 but with second it does not.
Similarly if I remove "ghConsoleprint("h1\n");" than PN532 does not perform peer to peer detection/communication error rate increases.
I am not sure what could be the problem.
Thank you.
Posted: Fri Feb 07, 2014 8:25 am
I don't recognize any of the functions you call in that code, how am I supposed to help? also, please keep requests on the appropriate forums.
