Connect to COM port via Hyper Terminal and Shell
Posted: Fri Feb 14, 2014 1:34 pm
by antoniolinux
Hi to all, I am a newbie of chibios and STM32F3 Discovery board,
i have this problem, i connect the board to pc, and all work well, i use blink example and i write easy example all work well.
Now i have this question:
when i connect the pc to usb-user (present on stm32f3) i can't connect to hyper terminal, I can not achieve it.
in presentation i see the possiblility to use kernel shell of chibios, but i can't active it
can you help me?
best regards
Antonio
Re: Connect to COM port via Hyper Terminal and Shell
Posted: Fri Feb 14, 2014 2:16 pm
Try the demo in ./testhal/STM32F30x/USB_CDC. It has a command line interface you can access through USB using a terminal emulator.
Posted: Mon Feb 17, 2014 11:28 am
by antoniolinux
thanks, giovanni all work well,
now i have only this question,if i wont use the shell in my project, i edit this example (./testhal/STM32F30x/USB_CDC ) and i adapt it for my problem,
have i understood right?
regards
Antonio
Posted: Mon Feb 17, 2014 12:01 pm
Just remove the shell related part.
