executing GPT etc callbacks in a thread, not ISR context
Posted: Mon Feb 17, 2014 5:25 pm
Hi, I'm new to ChibiOS. I compiled and run the RTOS on a STM32F103 dev board with simple ADC via DMA, multithreading demos etc. Now I wrote a simple own async implementation for sending RC switch-compliant commands to wireless AC sockets which is based on GPT callbacks/bitbanging.
The code works ok, the time diagram the method produces is perfect, yet I was slightly surprised by the fact that the OS concept dictates the callback code being executed in an ISR context - this is generally ok when the callback is fast and simple nor there's a need to use general API functions, but might be a problem otherwise. Moreover, the programmer has to always keep in mind which callback functions are called from an ISR, and which - from thread contexts.
I remember I used a ISR return address forging technique on a x86/MS-DOS to release the ISR context (store and patch ISR return address in the stack) - which frees the ISR context and runs the interrupt-driven user function in the user context. I wonder if such technique can (or planned to) be used in this RTOS for the callbacks? I understand that besides bringing in the cross-thread execution there might be platform-dependent restrictions from doing this - but on the other hand, you should be switching threads the alike manner in the scheduler.
Thank you,
Gleb
Thank you,
Gleb
