STM32F4-Discovery I/O Queue Chprintf Stack OverFlow Problem
Posted: Thu Mar 13, 2014 11:41 am
I wrote a simple program to test queues on STM32F4-Discovery with Chibios 2.6.3. In the first thread I add to the queue an element (a letter from A to F). In the second thread I take element of the queue and I display it using Chprintf. In addition, in the first thread I also toggle the LED.
The program works well for a few minutes and then freezes and pops up an error "stack overflow". I have increased the size of all possible stacks, but it did not help.
I have set all the debugging options as in the document: http://www.chibios.org/dokuwiki/doku.ph ... ebug_guide
Does anyone know what is wrong in my program?
ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "chprintf.h"
#define PORT_IDLE_THREAD_STACK_SIZE 0x0400
static uint8_t queueBuffer[20];
static INPUTQUEUE_DECL(inputQueueTest, &queueBuffer, 2000, NULL, NULL);
const SerialConfig sd2_config =
// SerialConfig for STM32 platforms
921600, // bit rate
0, // CR1 register settings
0, // CR2 register settings
0, // CR3 register settings
static WORKING_AREA(waThread1, 16000);
static msg_t HeartBeatThread(void *arg) {
(void)arg;
chRegSetThreadName("LED_HEARTBEAT");
CANRxFrame rxmsg1;
static int i = 0;
while (TRUE)
palSetPad(GPIOD, GPIOD_LED3);
chThdSleepMilliseconds(100);
palClearPad(GPIOD, GPIOD_LED3);
chThdSleepMilliseconds(700);
chSysLock();
int pull = chIQPutI(&inputQueueTest, 'A' + i);
chSysUnlock();
if(pull == Q_OK)
chprintf((BaseSequentialStream*)&SD2, "put ok\n");
if(pull == Q_FULL)
chprintf((BaseSequentialStream*)&SD2, "put full\n");
i++;
if (i == 6)
i = 0;
static WORKING_AREA(testQueue_wa, 8192);
static msg_t testQueue(void *arg)
(void)arg;
while(TRUE)
int Element = chIQGetTimeout(&inputQueueTest, MS2ST(200));
if(Element == Q_TIMEOUT)
chprintf((BaseSequentialStream*)&SD2, "TIMEOUT\n");
else if (Element == Q_RESET)
chprintf((BaseSequentialStream*)&SD2, "RESET\n");
else
chprintf((BaseSequentialStream*)&SD2, "element is %c\n", Element);
* Application entry point.
int main(void) {
* System initializations.
* RTOS is active.
chIQInit(&inputQueueTest, (uint8_t *)&queueBuffer, 2000, NULL, NULL);
* Activates the serial driver 2 using the driver default configuration.
* PA2(TX) and PA3(RX) are routed to USART2.
sdStart(&SD2, &sd2_config);
palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO, HeartBeatThread, NULL);
chThdCreateStatic(testQueue_wa, sizeof(testQueue_wa), NORMALPRIO, testQueue, NULL);
while (TRUE)
chThdSleepMilliseconds(1000);
