Page 1 of 2
[DONE] chprintf: float precision
Posted: Sun Mar 16, 2014 2:58 am
by russian
While chvprintf has 'precision' mentioned in the comment, it seems to me that currently the 'precision' variable is only used as maximum string length?
And %f is hard-coded to be five digit precision. Would you consider a patch which uses this variable for floating conversion precision?
Index: chprintf.c
--- chprintf.c (revision 6773)
+++ chprintf.c (working copy)
@@ -73,10 +73,12 @@
#if CHPRINTF_USE_FLOAT
-static char *ftoa(char *p, double num) {
+static char *ftoa(char *p, double num, unsigned long precision) {
long l;
- unsigned long precision = FLOAT_PRECISION;
+ if (precision == 0)
+ precision = FLOAT_PRECISION;
l = (long)num;
p = long_to_string_with_divisor(p, l, 10, 0);
*p++ = '.';
@@ -211,7 +213,7 @@
*p++ = '-';
f = -f;
- p = ftoa(p, f);
+ p = ftoa(p, f, precision);
break;
case 'X':
With this patch code like
chprintf(chp, "d %f\r\n", 0.12345678);
chprintf(chp, "0 %..1f\r\n", 0.12345678);
chprintf(chp, "3 %..1000f\r\n", 0.12345678);
chprintf(chp, "6 %..1000000f\r\n", 0.12345678);
outputs
(yes, with two dots between % and f)
Re: chprintf: float precision
Posted: Thu Mar 20, 2014 8:51 pm
Why the double dot? is this standard?
Posted: Thu Mar 20, 2014 8:56 pm
by russian
Let me try to figure out why the double dot. I just know that it works this way with just a 3 line change of the official source code - I am trying to minimize the patch.
The standard would probably be .5 instead of .10000 anyway, and 10000 is the default precision.
Posted: Thu Mar 27, 2014 3:03 am
by russian
The double dot is not standard, the double dot is existing Chibi implementation - the first dot turns off filler? something like that, the second dot is precision marker. I have not understood this implementation yet, but I am pretty sure that that's what is in the source code.
What is in the standard is that precision is defined as "%.2f" if you want to get "3.14" and not "3.1415"
Here is a patch which makes a step toward this by at least making precision configurable:
Index: os/various/chprintf.c
--- os/various/chprintf.c (revision 6820)
+++ os/various/chprintf.c (working copy)
@@ -32,7 +32,7 @@
#include "memstreams.h"
#define MAX_FILLER 11
-#define FLOAT_PRECISION 100000
+#define FLOAT_PRECISION 5
static char *long_to_string_with_divisor(char *p,
long num,
@@ -73,10 +73,15 @@
+static long pow10[] = {10, 100, 1000, 10000, 100000, 1000000, 10000000, 100000000, 1000000000, 10000000000, 100000000000, 1000000000000, 10000000000000};
long l;
+ precision = pow10[precision - 1];
l = (long)num;
*p++ = '.';
@@ -211,7 +216,7 @@
*p++ = '-';
f = -f;
- p = ftoa(p, f);
break;
case 'X':
Is there any chance for this patch to make it into the official source code?
Posted: Thu Mar 27, 2014 9:46 am
I need time to consider changes, chprintf is not exactly on top of priorities.
Posted: Wed Jun 25, 2014 11:08 pm
by enly1
Good timing - was just about to address this myself today as I need specific precision - manually added the patch by hand (don't know how to patch the code with tools) and got it working fine.
The only issue now is that the float handling doesn't actually work properly and has some rounding issues.
-2.123f @ 3 digit precision comes out as -2.122
-2.123f @ 5 digit precision comes out as -2.12299
But one for another night as its getting late ...
Posted: Fri Jun 27, 2014 5:18 pm
by skute
enly1 wrote:Good timing - was just about to address this myself today as I need specific precision - manually added the patch by hand (don't know how to patch the code with tools) and got it working fine.
This is the correct behavior for how chprintf is written. Floating point is an approximation; -2.123f equates to -2.12299991.
Posted: Fri Jun 27, 2014 11:12 pm
by enly1
Yes, I realised that - just not what I was expecting the function to perform.
I originally expected accurate responses at least to a few decimal places - so maybe my terminology was wrong - just need a different ftoa implementation.
Posted: Tue Jul 01, 2014 12:48 pm
by utzig
The reason for the two dots in float notation is that the filler code is accepting a dot too:
filler = ' ';
if ((*fmt == '.') || (*fmt == '0')) {
fmt++;
filler = '0';
This doesn't seem to be correct. Filler should be only '0' in this case:
http://www.cplusplus.com/reference/cstdio/printf/I think the code should be changed to:
filler = ' ';
if (*fmt == '0') {
fmt++;
filler = '0';
Best regards,
Fabio Utzig
Re: [TODO] chprintf: float precision
Posted: Tue Jul 01, 2014 12:54 pm
Added to the TODO list, I will merge both suggestions.
