STM32F4-Discovery ST7565 Driver
Posted: Wed Mar 19, 2014 8:29 pm
Hi all, I am pretty new to ChibiOS and I want to write an driver for ST7565 controller.
I have pre-existing C code for initialization and drawing characters on the LCD without using ChibiOS but want to implement this driver with ChibiOS.
Here is the code for main.c:
And here is the code which contains several functions like clearing the screen and printing character:
The problem is that I could initialize the screen without problem. Notice the 0xa5 in lcdinit variable which will turn all dots on. The LCD will do that without problem.
However, I cannot get other functions to work right with ChibiOS. For instance, I couldn't using Clear() to clear the dots on screen. My suspicion is the Setadd() function which sets the XY coordinate actually causes some problem but I don't know how to modify it since it's already working without ChibiOS.
Advice needed. Thank you!
ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "ST7565.h"
* This is a periodic thread that does absolutely nothing except flashing
* a LED.
(void)arg;
while (TRUE) {
palSetPad(GPIOD, GPIOD_LED3); /* Orange. */
chThdSleepMilliseconds(500);
palClearPad(GPIOD, GPIOD_LED3); /* Orange. */
static WORKING_AREA(spi_thread_1_wa, 256);
static msg_t spi_thread_1(void *p) {
(void)p;
chRegSetThreadName("blinker 2");
while (TRUE) {
palSetPad(GPIOD, GPIOD_LED5);
palClearPad(GPIOD, GPIOD_LED5);
* Application entry point.
int main(void) {
* System initializations.
* RTOS is active.
* Initializes the SPI driver 2. The SPI2 signals are routed as follow:
* PB12 - NSS.
* PB13 - SCK.
* PB14 - MISO.
* PB15 - MOSI.
palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
PAL_STM32_OSPEED_HIGHEST); /* New SCK. */
palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5) |
PAL_STM32_OSPEED_HIGHEST); /* New MISO. */
palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
PAL_STM32_OSPEED_HIGHEST); /* New MOSI. */
palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
PAL_STM32_OSPEED_HIGHEST); /* New CS. */
palSetPadMode(GPIOE, 8, PAL_MODE_OUTPUT_PUSHPULL |
PAL_STM32_OSPEED_HIGHEST); /* New A0. */
palSetPadMode(GPIOE, 9, PAL_MODE_OUTPUT_PUSHPULL |
PAL_STM32_OSPEED_HIGHEST); /* New RES. */
palClearPad(GPIOE, 12);
palClearPad(GPIOE, 8);
palClearPad(GPIOE, 9);
LcdInit();
//chThdSleep(1000);
Clear();
// disp_str("SKYWAVE VER 1.0",0,0);
// disp_str("STATUS:",0,2);
// disp_str("CONNECTED",75,2);
// disp_str("STRENGTH:",0,3);
// disp_str("*********",75,3);
// disp_str("TITLE:",0,4);
// disp_str("HEY JUDE",75,4);
// disp_str("PLAYTIME:",0,5);
// disp_str("5:32",75,5);
// disp_str("SETTING:",0,6);
// disp_str("ROCK",75,6);
// disp_str("VOLUME:",0,7);
// disp_str("30",115,7);
* Creates the example thread.
chThdCreateStatic(spi_thread_1_wa, sizeof(spi_thread_1_wa), NORMALPRIO + 1, spi_thread_1, NULL);
* sleeping in a loop and check the button state, when the button is
* pressed the test procedure is launched with output on the serial
* driver 2.
while (TRUE) {
#include "ch.h"
#include "hal.h"
#include "ST7565.h"
static uint8_t lcdinit[16] = {0xe2, 0xa0, 0xc8, 0x2f, 0x27, 0xaf, 0x40, 0xc8, 0xa6, 0xa4, 0xa3, 0x81, 0x0, 0xf8, 0x3, 0xa5};
static uint8_t lcdcmd[1] = {0};
static uint8_t lcddat[1] = {0};
//static void spicb(SPIDriver *spip);
// * SPI end transfer callback.
//static void spicb(SPIDriver *spip) {
// /* On transfer end just releases the slave select line.*/
// chSysLockFromIsr();
// spiUnselectI(spip);
// chSysUnlockFromIsr();
static const SPIConfig spicfg = {
NULL,
/* HW dependent part.*/
GPIOB,
12,
SPI_CR1_BR_0 | SPI_CR1_BR_1 | SPI_CR1_CPOL | SPI_CR1_CPHA
unsigned char CurOffset;
#define ASC_CHR_WIDTH 5
#define ASC_CHR_HEIGHT 12
#define ASC_HZ_WIDTH 16
typedef struct
char Index[1];
char Msk[5];
}typFNT_ASC16;
const typFNT_ASC16 ASC_16[] =
"*",0x14, 0x08, 0x3E, 0x08, 0x14,
".",0x60, 0x60, 0x00, 0x00, 0x00,
":",0x00, 0x00, 0x24, 0x00, 0x00,
" ",0x00, 0x00, 0x00, 0x00, 0x00,
"0",0x3e, 0x41, 0x41, 0x41, 0x3e,
"1",0x00, 0x42, 0x7F, 0x40, 0x00,
"2",0x71, 0x49, 0x49, 0x49, 0x46,
"3",0x41, 0x49, 0x49, 0x49, 0x36,
"4",0x1C, 0x12, 0x11, 0x7F, 0x10,
"5",0x4F, 0x49, 0x49, 0x49, 0x31,
"6",0x3E, 0x49, 0x49, 0x49, 0x30,
"7",0x01, 0x71, 0x09, 0x05, 0x03,
"8",0x36, 0x49, 0x49, 0x49, 0x36,
"9",0x06, 0x49, 0x49, 0x49, 0x3E,
"A",0x78, 0x16, 0x11, 0x16, 0x78,
"B",0x7f, 0x49, 0x49, 0x49, 0x36,
"C",0x3e, 0x41, 0x41, 0x41, 0x41,
"D",0x7f, 0x41, 0x41, 0x41, 0x3E,
"E",0x7f, 0x49, 0x49, 0x49, 0x41,
"F",0x7f, 0x09, 0x09, 0x09, 0x01,
"G",0x3e, 0x41, 0x49, 0x49, 0x79,
"H",0x7f, 0x08, 0x08, 0x08, 0x7f,
"I",0x00, 0x00, 0x7f, 0x00, 0x00,
"J",0x20, 0x40, 0x40, 0x3f, 0x00,
"K",0x7f, 0x08, 0x14, 0x22, 0x41,
"L",0x7f, 0x40, 0x40, 0x40, 0x40,
"M",0x7f, 0x06, 0x18, 0x06, 0x7f,
"N",0x7f, 0x06, 0x08, 0x30, 0x7f,
"O",0x3e, 0x41, 0x41, 0x41, 0x3e,
"P",0x7f, 0x09, 0x09, 0x09, 0x06,
"Q",0x3e, 0x41, 0x41, 0x21, 0x5e,
"R",0x7f, 0x09, 0x19, 0x29, 0x46,
"S",0x46, 0x49, 0x49, 0x49, 0x31,
"T",0x01, 0x01, 0x7f, 0x01, 0x01,
"U",0x3f, 0x40, 0x40, 0x40, 0x3f,
"V",0x07, 0x38, 0x40, 0x38, 0x07,
"W",0x3f, 0x40, 0x3c, 0x40, 0x3f,
"X",0x63, 0x14, 0x08, 0x14, 0x63,
"Y",0x03, 0x04, 0x78, 0x04, 0x03,
"Z",0x61, 0x51, 0x49, 0x45, 0x43
void Comwrite(u8 cmd)
Reset_A0; //A0=0;
spiAcquireBus(&SPID2); /* Acquire ownership of the bus. */
spiStart(&SPID2, &spicfg); /* Setup transfer parameters. */
spiSelect(&SPID2); /* Slave Select assertion. */
//Reset_CS;
lcdcmd[0] = cmd;
spiSend(&SPID2, 1, lcdcmd); /* Atomic transfer operations. */
//spiUnselect(&SPID2);
//Set_CS;
spiReleaseBus(&SPID2); /* Ownership release. */
void Datwrite(u8 dat)
Reset_A0; //A0=0;
Set_A0; //A0=1;
//Reset_CS;
lcddat[0] = dat;
spiSend(&SPID2, 1, lcddat); /* Atomic transfer operations. */
//Set_CS;
void Clear(void)
u8 i,j;
for(i=0;i<8;i++)
Setadd(0,i);
for(j=0;j<128;j++)
Datwrite(0x00);
void Setadd(u8 xl,u8 yl)
u8 i;
xl+=0;
i=(xl+0)&0x0f;
xl=(xl>>4)+0x10;
Comwrite(0xb0+yl);
Comwrite(xl);
Comwrite(i);
void LcdInit(void)
Reset_RES;
chThdSleepMilliseconds(50);
Set_RES;
Reset_A0; //A0=0;
spiSelect(&SPID2);
spiSend(&SPID2, 16, lcdinit); /* Atomic transfer operations. */
void disp_ch(unsigned char c,u8 uCol,u8 uPage)
unsigned char k,j,ch_w;
unsigned char width;
unsigned char len;
len=sizeof(ASC_16)/sizeof(ASC_16[0]);
for(k=0;k<len;k++)
if(c == ASC_16[k].Index[0] ) break;
if(k<len)
if(c=='-'||c==':')
width=ASC_CHR_WIDTH-2;
else if(c=='|')
width=ASC_HZ_WIDTH-ASC_CHR_WIDTH;
else
width=ASC_CHR_WIDTH;
Setadd(uCol,uPage);
for(j=0;j<width;j++)
ch_w=ASC_16[k].Msk[j];
Datwrite(ch_w);
void disp_str(u8 *p,u8 uCol,u8 uPage)
unsigned char i=0;
while(p[i]>0)
if(p[i] < 128)
disp_ch(p[i],uCol,uPage);
uCol+=6; // 6 depends on character width
i++;
