[DONE] MMC_SPI Driver Error
Posted: Fri Apr 11, 2014 7:26 pm
Hello.
The driver set 'mmcp->block_addresses' to TRUE and never reset it. So if I insert regular SD card after SDHC it is not working properly!
I propose to insert reset code in start of mmcConnect() like this:
file: ..\mmc_spi.c
489 /* Check if CCS is set in response. Card operates in block mode if set.*/
490 if (r3[0] & 0x40)
491 mmcp->block_addresses = TRUE;
449 /* Connection procedure in progress.*/
450 mmcp->state = BLK_CONNECTING;
451 mmcp->block_addresses = FALSE;
