Page 1 of 3
CCM section & "section `.bss' will not fit in region `ram'"
Posted: Thu Apr 17, 2014 8:41 pm
by russian
My fields do not fit in the primary RAM region and I am trying to put part of the fields into CCM but I wonder if I am missing something.
For instance, if I have
static char pendingBuffer[OUTPUT_BUFFER] __attribute__((section(".ccm")));
my binary links successfully and I see that 'pendingBuffer' is not present in the .map file as the other fields are and that makes me thing that 'pendingBuffer' was moved somewhere else, hopefully into CCM.
Now, if I change this line to
static char pendingBuffer[10000 + OUTPUT_BUFFER] __attribute__((section(".ccm")));
Suddenly the binary does not link anymore, the error message is
c:/program files (x86)/codesourcery/sourcery_codebench_lite_for_arm_eabi/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/bin/ld.exe: rusefi.elf section `.bss' will not fit in region `ram'
c:/program files (x86)/codesourcery/sourcery_codebench_lite_for_arm_eabi/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/bin/ld.exe: region `ram' overflowed by 6408 bytes
Why ram and not ccm ram? Probably because bss goes to ram, but what do I have to detach myself from .bss?
My linker script is
https://svn.code.sf.net/p/rusefi/code/t ... 7xG_CCM.ld - it's the default script with stack pointed into ram.
Re: CCM section & "section `.bss' will not fit in region `ra
Posted: Thu Apr 17, 2014 11:10 pm
by jscott
It looks like you are overeflowing the region by 6408 bytes.
RAM is 112K
CCM is 64K
How big is OUTPUT_BUFFER?
What other large memory allocations are you doing?
Can you provide a copy of the .map file?
That will tell just what is going where and how big it is.
-John Scott
Posted: Thu Apr 17, 2014 11:23 pm
by russian
The full source code is available @
https://svn.code.sf.net/p/rusefi/code/trunk/firmware/My make file is
https://svn.code.sf.net/p/rusefi/code/t ... e/Makefilemap file is
https://svn.code.sf.net/p/rusefi/code/t ... rusefi.mapI also have a script which makes the .map file a bit more readable - the result is @
https://svn.code.sf.net/p/rusefi/code/t ... report.txt#define OUTPUT_BUFFER 9000
It looks like the fields with the ccm attribute are not making it to the map file, I would love to have them in the map file so that I can get a better picture. I have a feeling that none of my fields are actually in the CCM segment and my total memory consumption is probably 110K exactly.
Posted: Fri Apr 18, 2014 1:59 am
by jscott
OK....
Here is your memory map
Memory Configuration
Name Origin Length Attributes
flash 0x08000000 0x00100000
ram 0x20000000 0x0001c000
ethram 0x2001c000 0x00004000
ccmram 0x10000000 0x00010000
OUTPUTBUFFER is located in normal ram.
You can search the .map file and you find it at:
.bss.logger 0x200130b4 0x104 build/obj/tunerstudio.o
.bss.outputBuffer <--- name of object
0x200131b8 0x2328 build/obj/datalogging.o <--- location, size, source
.bss.intermediateLoggingBufferInited
0x200154e0 0x1 build/obj/datalogging.o
You are using CCM, just not getting what you want into it...
You can see that things like _idle_thread_wa are being placed
at 0x10000050 which is in the CCM ( refer to the memory map above
if needed... )
.ccm 0x10000000 0x220
0x10000000 PROVIDE (_cmm_start, .)
0x10000000 . = ALIGN (0x4)
*(.bss.mainthread.*)
.bss.mainthread.4841
0x10000000 0x4c build/obj/chsys.o
0x1000004c . = ALIGN (0x4)
*(.bss._idle_thread_wa)
*fill* 0x1000004c 0x4 00
0x10000050 0x178 build/obj/chsys.o
0x10000050 _idle_thread_wa
0x100001c8 . = ALIGN (0x4)
*(.bss.rlist)
.bss.rlist 0x100001c8 0x1c build/obj/chschd.o
0x100001c8 rlist
0x100001e4 . = ALIGN (0x4)
*(.bss.vtlist)
.bss.vtlist 0x100001e4 0x10 build/obj/chvt.o
0x100001e4 vtlist
0x100001f4 . = ALIGN (0x4)
*(.bss.endmem)
.bss.endmem 0x100001f4 0x4 build/obj/chmemcore.o
0x100001f8 . = ALIGN (0x4)
*(.bss.nextmem)
.bss.nextmem 0x100001f8 0x4 build/obj/chmemcore.o
0x100001fc . = ALIGN (0x4)
*(.bss.default_heap)
*fill* 0x100001fc 0x4 00
.bss.default_heap
0x10000200 0x20 build/obj/chheap.o
0x10000220 . = ALIGN (0x4)
0x10000220 PROVIDE (_cmm_end, .)
The only remain issue is sorting out why OUTPUTBUFFER is not being placed
where you want it... I will take a look through your code when I get time and
see what I find. Not sure when, may be a few days....
But this give you
more information to work with. Post if you make any progress...
-John Scott
Posted: Fri Apr 18, 2014 2:20 am
by jscott
OK, pendingBuffer is not in your being placed in you memory map..
It may be because you have optimization turned on, and the compiler thing you are not using it and removed it.
in you linker file you need to change the optimization level from -O1 to -O0
# Compiler options here.
ifeq ($(USE_OPT),)
USE_OPT = $(RFLAGS) -O1 -fgnu89-inline -ggdb -fomit-frame-pointer -falign-functions=16 -std=gnu99 -Werror-implicit-function-declaration -Werror -Wno-error=pointer-sign -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=sign-compare -Wno-error=unused-parameter -Wno-error=missing-field-initializers
endif
optimization during development is a big no-no and will drive you and everyone
else crazy trying to figure out what is happening because it will move things around and delete code that you need, but the compiler does not thing you need.
Do that and post your status then...
-John Scott
Posted: Fri Apr 18, 2014 2:48 am
by russian
I've just tried with optimization off (-O0) but the error messages are exactly the same
I've checked in new version of the .map
As I've mentioned - interesting thing, 'pendingBuffer' is not mentioned in the .map file at all.
Posted: Fri Apr 18, 2014 4:40 am
by jscott
Ok, this is starting to stump me...
I looked over some code that I have that uses CCM and I only see one real difference.
It may be related to me using ChibiStudio, so this is a poke in the dark...
Try changing the section name from .ccm to .ccmbuf
Also, can you provide the full compile report? I want to see what other warnings you are getting. CCM does generate a couple of information messages and I want to see just what you are getting...
I am using
#define intoCCM __attribute__((section(".ccmbuf"))) __attribute__((aligned(4)))
In a header file, and
volatile framebuffer_t framebuffer[16][60] intoCCM;
to allocate my buffer. So I end up with:
*(.ccmbuf)
.ccmbuf 0x10000968 0xf00 build/obj/lightshow.o
0x10000968 framebuffer
0x10001868 PROVIDE (_cmm_end, .)
in my .map file
-John
Posted: Fri Apr 18, 2014 10:25 am
by fred
In his map file (
https://svn.code.sf.net/p/rusefi/code/t ... rusefi.map) why is there an association between .ccm and the 0x20000000 address base?
.ccm 0x200016a0 0x8358 load address 0x0802c8dc
.ccm 0x200016a0 0x4a38 build/obj/datalogging.o
.ccm 0x200060d8 0xd60 build/obj/flash_main.o
0x200060d8 flashState
.ccm 0x20006e38 0x1388 build/obj/wave_chart.o
.ccm 0x200081c0 0xe20 build/obj/trigger_central.o
.ccm 0x20008fe0 0xa18 build/obj/trigger_emulator_algo.o
0x20008fe0 configuration
.bss.outputBuffer comes from build/obj/datalogging.o which points at 0x200016a0
That makes sense because ...
.bss :
. = ALIGN(4);
PROVIDE(_bss_start = .);
*(.bss)
. = ALIGN(4);
*(.bss.*) <==============
. = ALIGN(4);
*(COMMON)
. = ALIGN(4);
PROVIDE(_bss_end = .);
} > ram <==============
So couldn't he just explicitly add outputBuffer to the linker?
.ccm :
PROVIDE(_cmm_start = .);
. = ALIGN(4);
*(.bss.outputBuffer) <======================
. = ALIGN(4);
. = ALIGN(4);
. = ALIGN(4);
*(.bss.rlist)
. = ALIGN(4);
*(.bss.vtlist)
. = ALIGN(4);
*(.bss.endmem)
. = ALIGN(4);
*(.bss.nextmem)
. = ALIGN(4);
. = ALIGN(4);
PROVIDE(_cmm_end = .);
} > ccmram
Edit:
or add a "*(.ccm)" instead of "*(.bss.outputBuffer)" to catch everything.
Posted: Fri Apr 18, 2014 11:14 am
by russian
On my.st.com forum I was advised to add
into the ccm section
this has helped - the binary does build now! The fields are still not appearing in the .map file
Will try the ccmbuf approach in a bit, have to run now
Posted: Fri Apr 18, 2014 5:08 pm
by jscott
Ok, we are dealing with different versions of the _ccm linker file...
.ccm :
. = ALIGN(4);
. = ALIGN(4);
. = ALIGN(4);
*(.bss.rlist)
. = ALIGN(4);
*(.bss.vtlist)
. = ALIGN(4);
*(.bss.endmem)
. = ALIGN(4);
*(.bss.nextmem)
. = ALIGN(4);
. = ALIGN(4);
KEEP(*(.ccmbuf))
} > ccmram
In mine, at the end of this section I have a line that says:
KEEP(*(.ccmbuf))
This will put anything that is declared like:
volatile framebuffer_t framebuffer[16][60] __attribute__((section(".ccmbuf")));
into the CCM
Simply adding
__attribute__((section(".my_section_name"))) will create a section named .my_section_name but unless the linker has instructions to place it in .CCM it will simply place it in .BSS as we have seen.
Russian's linker script does not have specific instructions as to what to do to a section named .CCM. So we either need to edit the linker script for each variable we want to add to CCM ( yuck... ), or add something like the KEEP(*(.ccmbuf)) line once and then just add
__attribute__((section(".ccmbuf"))); to any declarition that we want put in .CCM.
I know this is kind of mind bending, but the idea is to have a "standard" linker file and be able to choose where we want variables stored by changing how we declare them in the our source file, without having to also change the linker scripts.
I still don't know why pendingBuffer is missing....
One mystry solved ( i hope...), one to go ( only one! I hope.... )
-John Scott
