STM32F373 SDADC returns garbage
Posted: Fri Apr 18, 2014 9:22 pm
I'm trying to use SDADC on my board with STM32F373CB.
Analog inputs on PB0 (AIN6P), PB1 (AIN5P) connected to external pullup resistor, PB2 (AIN4P) to Vbat divider (1/3).
It does not matter closed inputs to ground or power, the result is always:
Configuration:
ISR & thread run:
At that gpio outputs meander near 2.8 kHz.
SDADC1: 64092 32767 32767
SDADC1: 32767 32767 32767
SDADC1: 64128 32767 32767
SDADC1: 64390 32767 32767
Configuration:
/* V bat, engine therm 1 & 2 (OIL) */
static const ADCConfig sdadc1cfg = {
.cr1 = 0,
.confxr = {
SDADC_CONFR_GAIN_1X | SDADC_CONFR_SE_ZERO_VOLT | SDADC_CONFR_COMMON_VSSSD,
0,
0}
static const ADCConversionGroup sdadc1group = {
.circular = TRUE,
.num_channels = 3,
.end_cb = adc_term_oilp_vbat_cb,
.error_cb = adc_error_cb,
.u.sdadc = {
.cr2 = SDADC_CR2_JSWSTART,
.jchgr = SDADC_JCHGR_CH(6) |
SDADC_JCHGR_CH(5) |
SDADC_JCHGR_CH(4),
.confchr = {
SDADC_CONFCHR1_CH6(0) |
SDADC_CONFCHR1_CH5(0) |
SDADC_CONFCHR1_CH4(0),
0
ISR & thread run:
static adcsample_t term_oilp_vbat_samples[3];
static void adc_term_oilp_vbat_cb(ADCDriver *adcp ATTR_UNUSED,
adcsample_t *buffer, size_t n ATTR_UNUSED)
//sma_insert(&m_term, buffer[0]);
//sma_insert(&m_oilp, buffer[1]);
//sma_insert(&m_vbat, buffer[2]);
/* SAME */
palTogglePad(GPIOE, GPIOE_STARTER);
static void adc_error_cb(ADCDriver *adcd ATTR_UNUSED, adcerror_t err ATTR_UNUSED)
//alert_component(ALS_ADC, AL_FAIL);
THD_FUNCTION(th_adc, arg ATTR_UNUSED)
/* SDADC1 */
adcStart(&SDADCD1, &sdadc1cfg);
adcSTM32Calibrate(&SDADCD1);
/* Start continous conversions */
adcStartConversion(&SDADCD1, &sdadc1group, term_oilp_vbat_samples, 1);
while (true) {
chThdSleepMilliseconds(1000);
//debug_printf(DP_DEBUG, "SDADC1: temp: %d oilp: %d vbat: %d",
// sma_get(&m_term),
// sma_get(&m_oilp),
// sma_get(&m_vbat));
debug_printf(DP_DEBUG, "SDADC1: %6d %6d %6d",
term_oilp_vbat_samples[0],
term_oilp_vbat_samples[1],
term_oilp_vbat_samples[2]);
/* notify ADC running */
//alert_component(ALS_ADC, AL_NORMAL);
