ChibiStudio preview 6
ChibiStudio preview 6 has been released, few updates:
*** Preview 6 ***
- Updated to ChibiOS/RT 2.6.4 stable.
- Updated to OpenOCD 0.8.0.
- Updated to gcc-arm-none-eabi-4_7-2014q2.
- Added alternate compiler: bleeding-edge-toolchain-140405 4.8.3.
  Use C:\ChibiStudio\start2.bat in order to use the alternate compiler.
I am very interested in feedback on the new Bleeding Edge Toolchain, I am thinking to make it default in next release.
xlh1460
Re: ChibiStudio preview 6
Post by xlh1460 »
I don't see it. Can you provide a link?
Uploading, it will appear on SF in about an hour.
http://sourceforge.net/projects/chibios ... ibiStudio/
I'm not a ChibiStudio user but I use the 4.8 toolchain since a very long time in all my projects. I have never faced any kind of issue if that helps.
xlh1460
Post by xlh1460 »
Do you mean the bleeding edge 4.8 tool chain or another?
Do you use a different IDE or command line?
Thanks for the info.
xlh1460
Post by xlh1460 »
Giovanni wrote:Uploading, it will appear on SF in about an hour.
Thank you. :)
xlh1460 wrote:Do you mean the bleeding edge 4.8 tool chain or another?
Do you use a different IDE or command line?.
Yes, I am talking about the bleeding edge 4.8 toolchain. I use it since it's been released in both ChibiOS/RT and non-ChibiOS/RT project and I never faced any issue.
I don't use any IDE at all for myself. I use a sane text editor and a makefile based build systems.
As µGFX customers often want some IDE-based solution or support, I am kinda forced sometimes to stick to eclipse but that's really rare. Personally I am currently evaluating Em::Blocks for my IDE of choice and I am really satisfied with it so far. I once posted a corresponding project template.
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
Is this using Eclipse Kelper ?
No, still Juno.
Korken
Has thanked: 5 times
Been thanked: 6 times
Post by Korken »
What is the time frame for supporting 3.0.0?
