ChibiOS has two UART implementations. Serial is simpler for using in terminal application.
Programm echoes byte to terminal.
Here is example for
- thread creation
- waiting for event
- receiving and transmiting to UART
Changes in halconf.h
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL TRUE
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE 115200 // set baudrate here
Choose USART1 in mcuconf.h
#define STM32_SERIAL_USE_USART1 TRUEmain.c
#include <ch.h>
#include <hal.h>
#include <stm32f10x.h>
static WORKING_AREA(waSerEcho, 128);
static msg_t thSerEcho(void *arg)
(void)arg;
chRegSetThreadName("SerEcho");
EventListener elSerData;
flagsmask_t flags;
chEvtRegisterMask((EventSource *)chnGetEventSource(&SD1), &elSerData, EVENT_MASK(1));
while (TRUE)
chEvtWaitOneTimeout(EVENT_MASK(1), MS2ST(10));
chSysLock();
flags = chEvtGetAndClearFlags(&elSerData);
chSysUnlock();
if (flags & CHN_INPUT_AVAILABLE)
msg_t charbuf;
do
charbuf = chnGetTimeout(&SD1, TIME_IMMEDIATE);
if ( charbuf != Q_TIMEOUT )
chSequentialStreamPut(&SD1, charbuf);
while (charbuf != Q_TIMEOUT);
return 0;
int main(void) {
sdStart(&SD1, NULL);
chThdCreateStatic(waSerEcho, sizeof(waSerEcho), NORMALPRIO, thSerEcho, NULL);
while (!chThdShouldTerminate()) {
chThdSleepMilliseconds(500);
return 0;
