IAR project setup
alb
IAR project setup
Post by alb »
How do I get IAR to search the ChibiOS_2.6.4 directory structure for the files needed to compile?
There is a spot in the Project > Options > C/C++ Complier > Preprocessor, to add directories, but it seems as though every leaf directory needs to be listed. Seems there should be an easier way.
Re: IAR project setup
If there is a more rational way then I have never found it. If you look at the various IAR demos you will see that all required directories are listed.
alb
Post by alb »
Thanks for your weekend help.
Added the directories one at a time, one for each error.
One step at a time. Now how about the linker. I am getting errors such as these:
Error[Li005]: no definition for "halInit" [referenced from C:\ChibiOS_2.6.4\projects\four_motor_iar\iar\Debug\Obj\main.o]
Error[Li005]: no definition for "chSysInit" [referenced from C:\ChibiOS_2.6.4\projects\four_motor_iar\iar\Debug\Obj\main.o]
Error[Li005]: no definition for "sdStart" [referenced from C:\ChibiOS_2.6.4\projects\four_motor_iar\iar\Debug\Obj\main.o]
Error[Li005]: no definition for "sduRequestsHook" [referenced from C:\ChibiOS_2.6.4\projects\four_motor_iar\iar\Debug\Obj\usbcfg.o]
Error[Li005]: no definition for "usbInitEndpointI" [referenced from C:\ChibiOS_2.6.4\projects\four_motor_iar\iar\Debug\Obj\usbcfg.o]
Error[Li005]: no definition for "sduConfigureHookI" [referenced from C:\ChibiOS_2.6.4\projects\four_motor_iar\iar\Debug\Obj\usbcfg.o]
Any hints?
Thanks, ALB
Make sure to include all the required files into the project. I suggest you start from one of the provided examples.
