Kinetis support in trunk
utzig
Been thanked: 20 times
Post by utzig »
Just finished adding support for some Kinetis parts which are now available on 3.0. I got preliminary support for KL25 (CM0+) and K20 (CM4). The boards with included demo are the Freescale Freedom KL25Z and K20D50M and the Teensy 3.0.
Much of the code comes from 2.6x port available on Github and some I wrote anew. Thanks also for the contributions/improvements made by colin and JCube.
And now the demo test outputs:
Freedom KL25Z:
*** ChibiOS/RT test suite
*** Kernel:       3.0.0dev
*** Compiled:     Aug  7 2014 - 12:48:59
*** Compiler:     GCC 4.8.4 20140526 (release) [ARM/embedded-4_8-branch revision 211358]
*** Architecture: ARMv6-M
*** Core Variant: Cortex-M0+
*** Port Info:    Preemption through NMI
*** Platform:     Kinetis
*** Test Board:   Freescale Freedom KL25Z
--- Test Case 1.1 (Threads, enqueuing test #1)
--- Result: SUCCESS
--- Test Case 1.2 (Threads, enqueuing test #2)
--- Result: SUCCESS
--- Test Case 1.3 (Threads, priority change)
--- Result: SUCCESS
--- Result: SUCCESS
--- Test Case 2.1 (Semaphores, enqueuing)
--- Result: SUCCESS
--- Test Case 2.2 (Semaphores, timeout)
--- Result: SUCCESS
--- Test Case 2.3 (Semaphores, atomic signal-wait)
--- Result: SUCCESS
--- Test Case 2.4 (Binary Semaphores, functionality)
--- Result: SUCCESS
--- Test Case 3.1 (Mutexes, priority enqueuing test)
--- Result: SUCCESS
--- Test Case 3.2 (Mutexes, priority return)
--- Result: SUCCESS
--- Test Case 3.3 (Mutexes, status)
--- Result: SUCCESS
--- Test Case 3.4 (CondVar, signal test)
--- Result: SUCCESS
--- Test Case 3.5 (CondVar, broadcast test)
--- Result: SUCCESS
--- Test Case 3.6 (CondVar, boost test)
--- Result: SUCCESS
--- Test Case 4.1 (Messages, loop)
--- Result: SUCCESS
--- Test Case 5.1 (Mailboxes, queuing and timeouts)
--- Result: SUCCESS
--- Test Case 6.1 (Events, registration and dispatch)
--- Result: SUCCESS
--- Test Case 6.2 (Events, wait and broadcast)
--- Result: SUCCESS
--- Test Case 6.3 (Events, timeouts)
--- Result: SUCCESS
--- Test Case 7.1 (Heap, allocation and fragmentation test)
--- Result: SUCCESS
--- Test Case 8.1 (Memory Pools, queue/dequeue)
--- Result: SUCCESS
--- Test Case 9.1 (Dynamic APIs, threads creation from heap)
--- Result: SUCCESS
--- Test Case 9.2 (Dynamic APIs, threads creation from memory pool)
--- Result: SUCCESS
--- Test Case 9.3 (Dynamic APIs, registry and references)
--- Result: SUCCESS
--- Test Case 10.1 (Queues, input queues)
--- Result: SUCCESS
--- Test Case 10.2 (Queues, output queues)
--- Result: SUCCESS
--- Test Case 11.1 (Benchmark, messages #1)
--- Score : 157724 msgs/S, 315448 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.2 (Benchmark, messages #2)
--- Score : 124773 msgs/S, 249546 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.3 (Benchmark, messages #3)
--- Result: SUCCESS
--- Test Case 11.4 (Benchmark, context switch)
--- Score : 486416 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.5 (Benchmark, threads, full cycle)
--- Score : 100185 threads/S
--- Result: SUCCESS
--- Test Case 11.6 (Benchmark, threads, create only)
--- Score : 142239 threads/S
--- Result: SUCCESS
--- Test Case 11.7 (Benchmark, mass reschedule, 5 threads)
--- Score : 39691 reschedules/S, 238146 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.8 (Benchmark, round robin context switching)
--- Score : 294540 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.9 (Benchmark, I/O Queues throughput)
--- Score : 422964 bytes/S
--- Result: SUCCESS
--- Test Case 11.10 (Benchmark, virtual timers set/reset)
--- Score : 393390 timers/S
--- Result: SUCCESS
--- Test Case 11.11 (Benchmark, semaphores wait/signal)
--- Score : 767760 wait+signal/S
--- Result: SUCCESS
--- Test Case 11.12 (Benchmark, mutexes lock/unlock)
--- Score : 453020 lock+unlock/S
--- Result: SUCCESS
--- Test Case 11.13 (Benchmark, RAM footprint)
--- System: 460 bytes
--- Thread: 68 bytes
--- Timer : 20 bytes
--- Semaph: 12 bytes
--- EventS: 4 bytes
--- EventL: 16 bytes
--- Mutex : 16 bytes
--- CondV.: 8 bytes
--- Queue : 36 bytes
--- MailB.: 40 bytes
--- Result: SUCCESS
Final result: SUCCESS
Freedom K20D50M:
*** Compiled:     Aug  7 2014 - 12:47:09
*** Architecture: ARMv7-ME
*** Core Variant: Cortex-M4
*** Port Info:    Advanced kernel mode
*** Test Board:   Freescale Freedom K20D50M
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 167099 msgs/S, 334198 ctxswc/S
--- Result: SUCCESS
--- Score : 133495 msgs/S, 266990 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 582816 ctxswc/S
--- Result: SUCCESS
--- Score : 99560 threads/S
--- Result: SUCCESS
--- Score : 143087 threads/S
--- Result: SUCCESS
--- Score : 41773 reschedules/S, 250638 ctxswc/S
--- Result: SUCCESS
--- Score : 317520 ctxswc/S
--- Result: SUCCESS
--- Score : 383104 bytes/S
--- Result: SUCCESS
--- Score : 405010 timers/S
--- Result: SUCCESS
--- Score : 663764 wait+signal/S
--- Result: SUCCESS
--- Score : 459524 lock+unlock/S
--- Result: SUCCESS
--- EventS: 4 bytes
--- CondV.: 8 bytes
--- Result: SUCCESS
Teensy 3.0:
*** Compiled:     Aug  7 2014 - 12:44:14
*** Test Board:   PJRC Teensy 3.0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 167032 msgs/S, 334064 ctxswc/S
--- Result: SUCCESS
--- Score : 133438 msgs/S, 266876 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 582592 ctxswc/S
--- Result: SUCCESS
--- Score : 99520 threads/S
--- Result: SUCCESS
--- Score : 143029 threads/S
--- Result: SUCCESS
--- Score : 41756 reschedules/S, 250536 ctxswc/S
--- Result: SUCCESS
--- Score : 317400 ctxswc/S
--- Result: SUCCESS
--- Score : 382956 bytes/S
--- Result: SUCCESS
--- Score : 434294 timers/S
--- Result: SUCCESS
--- Score : 663504 wait+signal/S
--- Result: SUCCESS
--- Score : 459352 lock+unlock/S
--- Result: SUCCESS
--- EventS: 4 bytes
--- CondV.: 8 bytes
--- Result: SUCCESS
Best Regards,
Fabio Utzig
Re: Kinetis support in trunk
Is there a free GDB server for those boards? we may consider supporting the demos in ChibiStudio if there is a working debugger.
utzig
Post by utzig »
The Freedom boards have an extra processor with a custom firmware named OpenSDA which supposedly also provides a GDB server. I only used it to send firmware and as a serial <-> usb converter. Might try the GDB functionality later to see if it works.
Fabio Utzig
Just a note,
The HAL 3.0 does not more support the RT counters, all the related macros (HAL_IMPLEMENTS_COUNTERS) and functions are no more required. The kernel now support RT counters directly.
colin
Post by colin »
Giovanni wrote:Is there a free GDB server for those boards? we may consider supporting the demos in ChibiStudio if there is a working debugger.
I've used a Segger J-Link with the Freedom FRDM-KL25Z, and it works great. I just had to solder on the 10-pin Cortex Debug header. But the OpenSDA is a nice convenient concept. I think the newer P&E Micro firmware for the OpenSDA debug chip may be better (and there is a CMSIS-DAP version, I think...?).
colin
Post by colin »
utzig wrote:Hi,
Hi Fabio,
Thanks for all your work on this, I'm glad to see it moving on to the 3.0 trunk. I am torn between STM32 and Kinetis in many cases, they both have pros and cons, and if ChibiOS has good support for various members of the Kinetis family, between STM32 and Kinetis it will make for a fantastic range of options for every kind of embedded system.
SpaceCoaster
Post by SpaceCoaster »
I think the current kinetis code is missing the flash protection support. The .cfmconfig section (0x400-0x40F) is all zeroes.
The Chibios-Kinetis repository on github does have initialization for the .cfmconfig section so it looks like it was missed during the transfer.
Looking forward to trying this on a Teensy 3.1 soon.
Cheers,
Derek
utzig
Post by utzig »
You are right, SpaceCoaster. I saw that when reviewing against my github repo before commit but since it was working ok, I just left it out to add later. It's not exactly top of priorities right now but if you find any problem just post it here.
I only have the Teensy 3.0. If the 3.1 requires any changes please contribute them back. I used the first three pins on the Teensy 3.0 for the serial port (GND/TX/RX). You'll also need a TTL converter (I used the buspirate).
Fabio Utzig
SpaceCoaster
OK, pleased that I hit a target!
Those flash protection bits have the ability to lock the chip up from all flashing. A long time ago I managed to brick a MK22 by flashing code over those bits. It seems a very strange place to put protection bits.
Programming zeros into bits 1 and 0 of FTFL_FSEC.SEC will put the flash into secure mode and will prevent further writes BUT it is recoverable by erasing as long as FTFL_FSEC.MEEN has not been set to 10.
So zeros seems OK, random data not so.
Thanks for the port,
Derek
utzig
Post by utzig »
Derek,
I moved the flash protection to HAL. I copied your code from the RT-MCHCK-K20-SPI but changed one register. Yours had the following value/comments for FTFL_FSEC:
0xBE,  /* NV_FSEC: KEYEN=1,MEEN=3,FSLACC=3,SEC=2 */
But then NV_FSEC=1 would give 0x7 in the highest nibble. KEYEN=1 is probably better; manual states "01 Backdoor key access disabled (preferred KEYEN state to disable backdoor key access)". So the corrected is:
0x7E,  /* NV_FSEC: KEYEN=1,MEEN=3,FSLACC=3,SEC=2 */
If you can, please confirm I did no wrong here!
Cheers,
Fabio Utzig
