[DONE][STM32F30x] 144MHz PWM
Posted: Fri Aug 08, 2014 7:44 pm
by tecnologic
Hi All,
i finaly found the problem with setting the 144MHz Clock source for the advanced Timers.
RCC->CFGR3 = STM32_UART5SW   | STM32_UART4SW   | STM32_USART3SW |
               STM32_USART2SW  | STM32_TIM8SW    | STM32_TIM1SW   |
               STM32_I2C2SW    | STM32_I2C1SW    | STM32_USART1SW;
#if STM32_ACTIVATE_PLL
  /* PLL activation.*/
  RCC->CR   |= RCC_CR_PLLON;
  while (!(RCC->CR & RCC_CR_PLLRDY))
    ;                                       /* Waits until PLL is stable.   */
As u can see the PLL is activated after the bits STM32_TIM1SW and STM32_TIM8SW were "set" but they are not set cause:
The bit is writable only when the following conditions occur: clock system = PLL, and AHB
and APB2 subsystem clock not divided respect the clock system.
The bit is reset by hardware when exiting from the previous condition (user must set the bit
again in case of a new switch is required)
So these bits could not be set before the pll is running. They stay 0. I only moved the set of RCC->CFGR3 to the end of the function.
hope this solves the problem with the hal finally :).
Greetings
Tec
Re: [DONE][STM32F30x] 144MHz PWM
Posted: Wed Aug 13, 2014 3:28 pm
Thanks for finding. I had to add some extra checks to hal_lld.h, could you give the fix a try? I have no F3 HW where I am.
Fixed as bug #525.
Posted: Wed Aug 13, 2014 5:42 pm
by tecnologic
this was not the hole fix. The bits will only set when the clock source is switched to pll. please have look at these changes;
https://bitbucket.org/Tecnologic/chibio ... 2528821d30
os/hal/ports/STM32/STM32F30x/hal_lld.c
                STM32_HPRE;
   RCC->CFGR2 = STM32_ADC34PRES | STM32_ADC12PRES | STM32_PREDIV;
+  RCC->CFGR3 = STM32_UART5SW   | STM32_UART4SW   | STM32_USART3SW |
+               STM32_USART2SW  | STM32_I2C2SW    | STM32_I2C1SW   |
+               STM32_USART1SW;
-  /* After PLL activation because the special requirements for TIM1 and
-     TIM8 bits.*/
-  RCC->CFGR3 = STM32_UART5SW   | STM32_UART4SW   | STM32_USART3SW |
-               STM32_USART2SW  | STM32_TIM8SW    | STM32_TIM1SW   |
-               STM32_I2C2SW    | STM32_I2C1SW    | STM32_USART1SW;
   /* Flash setup and final clock selection.   */
   FLASH->ACR = STM32_FLASHBITS;
   while ((RCC->CFGR & RCC_CFGR_SWS) != (STM32_SW << 2))
     ;                                       /* Waits selection complete.    */
+  /* After PLL activation because the special requirements for TIM1 and
+     TIM8 bits.*/
+  RCC->CFGR3 |= STM32_TIM8SW    | STM32_TIM1SW;
 #endif /* !STM32_NO_INIT */
Änderungen nebeneinander Datei anzeigen
os/hal/ports/STM32/STM32F30x/hal_lld.h
 #elif STM32_TIM1SW == STM32_TIM1SW_PLLX2
 #if (STM32_SW != STM32_SW_PLL) ||                                           \
     (STM32_HPRE != STM32_HPRE_DIV1) ||                                      \
-    (STM32_PPRE2 != STM32_PPRE2_DIV2)
+    (STM32_PPRE2 != STM32_PPRE2_DIV1)
 #error "double clock mode cannot be activated for TIM1 under the current settings"
 #define STM32_TIM1CLK               (STM32_PLLCLKOUT * 2)
 #elif STM32_TIM8SW == STM32_TIM8SW_PLLX2
 #error "double clock mode cannot be activated for TIM8 under the current settings"
 #define STM32_TIM8CLK               (STM32_PLLCLKOUT * 2)
With this changes the clock config will be set correctly, verified on my custom stm32f303RC Board and on the F3Discovery. Both work as expected.
Regards
Tec
Posted: Wed Aug 13, 2014 5:59 pm
Change committed, thanks.
Posted: Wed Aug 13, 2014 7:25 pm
by tecnologic
Thanks, pulled the change.
Change tested and worked.
Regards
Tec
