chcoreasm compilation with GCC
Posted: Mon Aug 11, 2014 7:48 am
by Michail
Hello again!
I've remembered one old problem that I still have.
I use GNU Tools for ARM Embedded Processors with CoIDE and when compiling projects with ChibiOS I'm getting this error:
       [cc] arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb -Wall -ffunction-sections -g -O2 -flto -fno-builtin -c -DSTM32F050F4 -DSTM32F0XX_LD -DUSE_STDPERIPH_DRIVER -D__ASSEMBLY__ -DDEBUG_Discovery -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\osal -IC:\Work\CoIDE\ChibiOS_3.0_Test -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\DS18B20 -IC:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\include "-IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\Command Shell"
C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chstats.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\compilers\GCC\chcoreasm_v6m.s
C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chcond.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_misc.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chqueues.c C:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\src\nRF24.c
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\compilers\GCC\chcoreasm_v6m.s: Assembler messages:
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\compilers\GCC\chcoreasm_v6m.s:135: Error: symbol `.L3' is already defined
Looks like problems with Macro definitions like
#if CORTEX_ALTERNATE_SWITCH
#else
and others I think.
Looking at Linux Assembly HOWTO I've found that
3.2.5. Macro support
GAS has some macro capability included, as detailed in the texinfo docs. Moreover, while GCC recognizes .s files as raw assembly to send to GAS, it also recognizes .S files as files to pipe through CPP before feeding them to GAS. Again and again, see Linux sources for examples.
So when I'm renaming "chcoreasm_v6m.s" to "chcoreasm_v6m.S" everithing is compiling fine.
It's not a big problem for me, and I don't know if it'll work on other GCC implementations, but just as a thought for you about greater portability of ChibiOS... :)
With respect,
Michail
Re: chcoreasm compilation with GCC
Posted: Mon Aug 11, 2014 8:48 am
You can assemble using "gcc -x assembler-with-cpp" and there is no need for the .S.
Posted: Mon Aug 11, 2014 9:45 am
by Michail
Seems like not a case for CoIDE (CooCox). It generates gcc command line itself, for all of source files simultaneously (.c, .h and .s in one command line). So when I'm adding -x assembler-with-cpp to its options, I gets:
       [cc] 84 total files to be compiled.
       [cc] arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb -Wall -ffunction-sections -g -O2 -flto -fno-builtin "-x assembler-with-cpp" -c -DSTM32F050F4 -DSTM32F0XX_LD -DUSE_STDPERIPH_DRIVER -D__ASSEMBLY__ -DDEBUG_Discovery -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\osal -IC:\Work\CoIDE\ChibiOS_3.0_Test -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\DS18B20 -IC:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\include "-IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\Command Shell" -IC:\Work\CoIDE\ChibiOS_3.0_Test\cmsis_boot -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD -IC:\Work\CoIDE\ChibiOS_3.0_Test\board -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\common -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\include -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\common\ARMCMx -IC:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\FloorHeater -IC:\Work\CoIDE -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\STM32F0xx -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\include -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\USARTv2 -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\osal\rt -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\various -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\compilers\GCC -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\RGBW -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32 -IC:\Work\CoIDE\ChibiOS_3.0_Test\os -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\SPIv2 -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\rt -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\compilers -IC:\Work\CoIDE\ChibiOS_3.0_Test\nRF24 -IC:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\inc -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\core -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\Watchdog -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\common\ports\ARMCMx\devices -IC:\Work\CoIDE\ChibiOS_3.0_Test\board\STM32F050F -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\common\ports\ARMCMx\devices\STM32F0xx -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\common\ports\ARMCMx -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal -IC:\Work\CoIDE\ChibiOS_3.0_Test\cmsis_core -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\TIMv1 -IC:\Work -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\LCD1602 C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chsem.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\common\ports\ARMCMx\compilers\GCC\vectors.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\icu.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chdynamic.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\st.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\serial_usb.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\spi.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chmboxes.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\i2c.c C:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\src\nRF24_HAL.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\core\core.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_rcc.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\FloorHeater\FloorHeater.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chheap.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\hal_mmcsd.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chvt.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\SPIv2\spi_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\Watchdog\iwdg.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chmempools.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\TIMv1\pwm_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chstats.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\compilers\GCC\chcoreasm_v6m.s C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\pwm.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\uart.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chevents.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\sdc.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\hal_queues.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\DS18B20\DS18B20.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\USARTv2\serial_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\main.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\STM32F0xx\ext_lld_isr.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\usb.c C:\Work\CoIDE\ChibiOS_3.0_Test\cmsis_boot\startup\startup_stm32f0xx.s C:\Work\CoIDE\ChibiOS_3.0_Test\board\STM32F050F\board.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chdebug.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\STM32F0xx\hal_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_dma.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chsys.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\ext.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\can.c C:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\src\radio.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chtm.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\dac.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chschd.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\Watchdog\iwdg_lld.c '"C:\Work\CoIDE\ChibiOS_3.0_Test\modules\Command Shell\cli.c"' C:\Work\CoIDE\ChibiOS_3.0_Test\cmsis_boot\system_stm32f0xx_temp.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chregistry.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\DS18B20\onewire.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\pal.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_gpio.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chmemcore.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\chcore_v6m.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\STM32F0xx\stm32_dma.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\TIMv1\icu_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_usart.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\adc.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chmtx.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\i2s.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\various\shell.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\various\chprintf.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\gpt.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\hal.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chthreads.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\LCD1602\lcd.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_exti.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\ports\ARMCMx\chcore.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\TIMv1\st_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chmsg.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\common\ARMCMx\nvic.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\TIMv1\gpt_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\serial.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\src\mmc_spi.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\STM32F0xx\adc_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\USARTv2\uart_lld.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\common\ports\ARMCMx\compilers\GCC\crt0.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_syscfg.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\osal\rt\osal.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\Watchdog\WatchDog.c C:\Work\CoIDE\ChibiOS_3.0_Test\modules\RGBW\RGBW.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chcond.c C:\Work\CoIDE\ChibiOS_3.0_Test\stm32_lib\src\stm32f0xx_misc.c C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\src\chqueues.c C:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\src\nRF24.c
       [cc] arm-none-eabi-gcc: error: language  assembler-with-cpp not recognized
If I use "-Wp,-x assembler-with-cpp", I get:
       [cc] arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb -Wall -ffunction-sections -g -O0 -flto -fno-builtin "-Wp,-x assembler-with-cpp" -c -DSTM32F050F4 -DSTM32F0XX_LD -DUSE_STDPERIPH_DRIVER -D__ASSEMBLY__ -DDEBUG_Discovery -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\osal -IC:\Work\CoIDE\ChibiOS_3.0_Test -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\DS18B20 -IC:\Work\CoIDE\ChibiOS_3.0_Test\nRF24\include "-IC:\Work\CoIDE\ChibiOS_3.0_Test\modules\Command Shell"
       [cc] cc1.exe: error: command line option '-x assembler-with-cpp' is valid for the driver but not for C
PS: If I set "-x; assembler-with-cpp", I get a lot of:
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\include/ch.h: Assembler messages:
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\rt\include/ch.h:67: Error: bad instruction `typedef struct thread thread_t'
       [cc] c:\program files\gnu tools arm embedded\4.8 2014q2\lib\gcc\arm-none-eabi\4.8.4\include\stddef.h:147: Error: bad instruction `typedef int ptrdiff_t'
       [cc] c:\program files\gnu tools arm embedded\4.8 2014q2\lib\gcc\arm-none-eabi\4.8.4\include\stddef.h:212: Error: bad instruction `typedef unsigned int size_t'
       [cc] c:\program files\gnu tools arm embedded\4.8 2014q2\lib\gcc\arm-none-eabi\4.8.4\include\stddef.h:324: Error: bad instruction `typedef unsigned int wchar_t'
       [cc] c:\program files\gnu tools arm embedded\4.8 2014q2\arm-none-eabi\include\machine\_default_types.h:27: Error: bad instruction `typedef signed char __int8_t'
       [cc] c:\program files\gnu tools arm embedded\4.8 2014q2\arm-none-eabi\include\machine\_default_types.h:28: Error: bad instruction `typedef unsigned char __uint8_t'
Posted: Mon Aug 11, 2014 10:29 am
It is a gcc option not a gas option, you are passing it to gas.
Posted: Mon Aug 11, 2014 10:42 am
by Michail
In last case it passed to gcc I think, but as I see, it tries to build all sources (and .c and .h files) as asm:
       [cc] arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb -Wall -ffunction-sections -g -O2 -flto -fno-builtin -x assembler-with-cpp -c -DSTM32F050F4 -DSTM32F0XX_LD -DUSE_STDPERIPH_DRIVER -D__ASSEMBLY__ -DDEBUG_Discovery -IC:\Work\CoIDE\ChibiOS_3.0_Test\modules -IC:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\osal ...
Posted: Mon Aug 11, 2014 11:08 am
Sorry, I never used that IDE, I am just an old fashioned guy who loves the simplicity of makefiles :)
Posted: Mon Aug 11, 2014 1:07 pm
by Michail
Yes, it's not not as flexible as makefiles :) But much simpler for newbies.
BTW I liked your ChibiStudio, but it seemed to me a bit of unfinished when I've tried it half of year ago, and I went back to CoIDE.
But now, when I deeper falled into ChibiOS, I think I can give it a try again when I'll have some free time to port my apps :)
Anyway, renaming .s to .S is not a big problem for me.
