ICU problem.
Posted: Sun Aug 17, 2014 11:16 am
Hello, i am new to chibios and trying to get ICU to capture the pulse width generated by external source(button for now), i am trying to use timer 4 but it doesnt seem to work at all. I enabled icu in halconf.h and mcuconf.h and use the following code as implementation. Note that print_number() function works as intended. Version of chibios i use is 2.6.3.
static const ICUConfig icumyconfig = {
ICU_INPUT_ACTIVE_HIGH,
100,
myicucb,
icuperiodcb,
NULL,
ICU_CHANNEL_1,
0
icucnt_t width;
static void myicucb(ICUDriver *icup) {
width = icuGetWidth(icup);
print_number(width,&SD1);
icucnt_t last_period;
static void icuperiodcb(ICUDriver *icup) {
last_period = icuGetPeriod(icup);
int main(void) {
* System initializations.
* RTOS is active.
* Activates the serial driver 1 using the driver default configuration.
sdStart(&SD1, NULL);
palSetPadMode(GPIOB, PAL_PORT_BIT(6), PAL_MODE_STM32_ALTERNATE_PUSHPULL);
icuStart(&ICUD4, &icumyconfig);
icuEnable(&ICUD4);
