FATFS without heap support
Posted: Wed Aug 20, 2014 9:33 am
Hello all, I am trying to remove the heap memory allocation from a project of mine.
It seems like heap memory allocation is required for fatfs lfn support, so I were trying to remove the lfn support (_USE_LFN 0) and to set heap memory allocation setting to false.
While I compile the project, I gain:
../ChibiOS/ext/fatfs/src/option/ccsbcs.c:497:2: error: #error This file is not needed in current configuration. Remove from the project.
ccsbcs is fatfs related file.
In your opinion, is it a good idea to remove heap support and build totally static project? if yes, how do I get through the error above?
thanks.
-g
thanks.
-g
