Page 1 of 12
ST-Link V2 on Linux/OSX/Windows
Posted: Tue Nov 22, 2011 5:32 pm
by mobyfab
Hey guys,
I'm currently using Linux as my primary desktop for developping, and the lack of support for ST Link is kinda annoying...
Basically there are 2 options to my knowledge: http://code.google.com/p/arm-utilities/ or using the official tool under Windows :D
I have tested the above (Linux) solution with my STM34F4DISCOVERY and it didn't work, sadly... I guess there are some errors on the addresses descriptions.
I started developping a GUI based on QT4/libusb-1.0, so far most of the work is pretty much porting stlink-download to C++.
Once I get something working I'll post it to google code and try to add some features.
Any help/ideas are welcome.
I will let you know about my progress. :)
edit:
the code and the win32 binary are available here:
http://code.google.com/p/qstlink2/
Re: ST-Link V2 on Linux
Posted: Tue Nov 22, 2011 6:40 pm
Sure, keep us updated, I would also suggest supporting MacOS if possible, I know that there are many users using that too.
Posted: Tue Nov 22, 2011 6:50 pm
by mobyfab
It should work on OSX as well ;)
Posted: Wed Nov 23, 2011 7:47 pm
by mobyfab
okay, I've made a little progress:
I can now communicate with the ST-Link (Get version, mode...).
Now comes the reverse engineering, I'll have to use a windows VM on my linux host to do some more USB sniffing with wireshark. That way I'll see how the official application works.
I'll keep you posted.
Posted: Wed Nov 23, 2011 8:02 pm
by mabl
Mobyfab, great work! Just one question though: Why don't you use https://github.com/texane/stlink.git? It works great for my Discovery board under Fedora 16 and Ubuntu 11.10 - of cause it does not have a graphical interface.
I could also imagine that it can be compiled on OS X.
Posted: Wed Nov 23, 2011 10:04 pm
by mobyfab
Thanks for the link, I'll have a look :)
Indeed I'd like to have a GUI, it's just more practical in most cases, and C++ code is way easier to maintain that C code :P
Posted: Sun Nov 27, 2011 11:33 am
by mobyfab
I got it working :)
so far the only thing that I need to implement is the file transfer methods, everything else is working fine. (status, debug, reading/writing memory)
also, I'm using xml to specify info on the MCUs (cpuid, ram size, etc), so that can be changed without recompiling.
I'll post a screenshot later on.
as soon as it is ready I'll post the code on google.
Posted: Mon Nov 28, 2011 10:36 am
by mobyfab
here are the screenshots
I'm using my STM32F4DISCOVERY board.
Posted: Mon Nov 28, 2011 4:07 pm
Very cool, I wish to make a small request :-)
Would be possible to give it a command line interface able to brutally flash and run the device with a file (bin/hex) passed as parameter?
The command line version would be more make-friendly, I could add a specific target to makefiles. Of course log/errors would go on stdout/stderr.
Posted: Mon Nov 28, 2011 8:44 pm
by mobyfab
Yeah I can do this no problem.
had some issues with unlocking the flash, but now it is sorted. Last steps are erasing and programming then I'm done :D
