Bug in pal_lld.c
Posted: Sun Oct 12, 2014 12:58 am
the initial pin output state is not set correctly.
The problem is, that a write to PIO_ODSR does not work before PIO_OWER has been set.
This can be fixed easily by writing to the PIO_SODR and PIO_CODR registers which works even when PIO_OWER is not set.
Cheers,
Vinz
AT91C_BASE_PIOA->PIO_SODR = config->P0Data.odsr; /* Data as specified.*/
AT91C_BASE_PIOA->PIO_CODR = ~config->P0Data.odsr;
AT91C_BASE_PIOB->PIO_SODR = config->P1Data.odsr; /* Data as specified.*/
AT91C_BASE_PIOB->PIO_CODR = ~config->P1Data.odsr;
Cheers,
Vinz
