Raspberry Pi with ARM11-BCM2835 (Serial over USB)
Posted: Sun Jan 04, 2015 2:17 pm
by erusso
Hello! I'm really new in this and i need some helps.
I followed this tutorial http://www.stevebate.net/chibios-rpi/GettingStarted.html to compile ChibiOS into Raspberry Pi.
The blinker works correctly but I can´t see the outputs of "chprintf" in the serial Port over USB. :cry:
I don´t see any ttysX that can connect a serial monitor.
I need hard helps from you ;)
I'm working over OS X.
Thanks all.
Re: Raspberry Pi with ARM11-BCM2835 (Serial over USB)
Posted: Tue Jan 06, 2015 10:27 pm
It looks like the device is not enumerated by the host, not sure why. You should try contacting the author of the port.
