Page 1 of 2
full MapleMini support
Posted: Fri Jan 09, 2015 4:59 am
by dpiegdon
Hi!
I spent a little bit of time to improve the support for the MapleMini and its bootloader (STM32F103xE).
Also I created a demo for the board, including a blinker-thread and a full serial/usb shell, similar to many of the other examples.
The attached file should apply to the current trunk of chibios.
Re: full MapleMini support
Posted: Fri Jan 09, 2015 12:57 pm
by utzig
Some suggestions:
  • Your board.h uses tabs in your defined GPIO pins. Standard is to use spaces.
  • Copyright lines with "Copyright (C) 2006-2014 Giovanni Di Sirio" could probably be updated to "Copyright (C) 2006-2015 Giovanni Di Sirio"
  • CDC manufacturer string (vcom_string1) should probably be changed from "STMicroelectronics" to "LeafLabs". Just for convetion...
This looks good to be applied upstream IMO!
Cheers,
Fabio Utzig
Posted: Fri Jan 09, 2015 2:05 pm
I will apply it and remove tabs.
The code will soon go through a mass re-licensing so no problems there (I have a tool for that).
Thanks for the patch.
Posted: Fri Jan 09, 2015 4:17 pm
by dpiegdon
hi,
2015... yeah you are right, i forgot :-)...
i fixed the mentioned points, please find the new patch attached.
What I don't like about it - maybe you can help here - this uses the STM32F407 usb vendor/product IDs:
Bus 002 Device 019: ID 0483:5740 STMicroelectronics STM32F407
Now i know that vendor/product IDs are expensive to obtain, but i've been using the maplemini just for a few days and maybe they have one allocated and you know about it?
Posted: Fri Jan 09, 2015 5:13 pm
by utzig
Yeah, it looks like they have their own IDs:
#define LEAFLABS_ID_VENDOR                0x1EAF
#define MAPLE_ID_PRODUCT                  0x0004
https://github.com/leaflabs/libmaple/blob/master/libmaple/usb/stm32f1/usb_cdcacm.c#L89
Cheers
Posted: Fri Jan 09, 2015 5:27 pm
by dpiegdon
ah excellent! lets use them, then.
Posted: Fri Jan 09, 2015 5:32 pm
by utzig
Since Giovanni already signaled he will commit the original patch I would suggest that you send your changes as extra patches over HEAD when the original or v2 patches are applied.
Cheers
Posted: Fri Jan 09, 2015 8:59 pm
I haven't committed anything yet, please submit your final code, I will wait.
Posted: Fri Jan 09, 2015 9:47 pm
by utzig
Giovanni,
His last patch (v3) has everything in it. I would just suggest fixing the comment on line 36 of usbcfg.c from:
0x1eaf,        /* idVendor (ST).                   */
to:
0x1eaf,        /* idVendor (LeafLabs).                   */
Cheers
Posted: Fri Jan 09, 2015 10:18 pm
by dpiegdon
yes, utzigs last comment is correct.
please use v3 with the vendor name in usbcfg.c fixed to LeafLabs.
