Page 1 of 2
STM32F107 DAC on chibios 2.6.4
Posted: Fri Jan 09, 2015 5:19 pm
by Augustarello
Hallo!
I'd like to start the DAC driver on my Olimex STM32P107 board.
I've been working on Chibios branch 2.6.4, and this driver is not
there natively.
What would you suggest me, to wait for Chibi ver 3.0, or
instead to link it in my source tree myself?
In this case, I'd appreciate to receive the link for a stable
dac patch.
Bye,
A.
Re: STM32F107 DAC on chibios 2.6.4
Posted: Fri Jan 09, 2015 8:56 pm
There is not such a thing, if you search in the forum you will find several contributed DAC drivers, none of them is final.
giovanni
Posted: Sun Jan 11, 2015 3:21 pm
by mobyfab
Give this one a try, but you will have to tweak some options.
https://github.com/ChibiOS/ChibiOS-Drivers ;)
There is a 2.6 branch.
Posted: Thu Jan 15, 2015 10:34 pm
by Augustarello
I've done, it seems to work!
I've just tried to generate dac voltage outputs
using "dacConvert(&DACD1,dac_value)".
For sake of completeness, in my main.c i've made
the following modifications:
+ #include "drivers.h"
+ static const DACConfig daccfg = {
DAC_DHRM_12BIT_RIGHT, /* data holding register mode */
0 /* DAC CR flags */
+ dacStart(&DACD1, &daccfg);
+ dacConvert(&DACD1,dac_value);
In order to compile this driver, the instructions available
in file "readme.md" are not enough, i've had to include
drivers_conf.h, as visible below and finally to
modify my original halconf.h adding the following lines:
+#if !defined(HAL_USE_DAC) || defined(__DOXYGEN__)
+#define HAL_USE_DAC TRUE
+#endif
This is my drivers_conf.h
 * drivers_conf.h
 *  Created on: 14/gen/2015
 *      Author: gluca
#ifndef DRIVERS_CONF_H_
#define DRIVERS_CONF_H_
 * @brief   Enables the Drivers.
#if !defined(DRIVER_USE_DAC) || defined(__DOXYGEN__)
#define DRIVER_USE_DAC                 TRUE
#if !defined(DRIVER_USE_IWDG) || defined(__DOXYGEN__)
#define DRIVER_USE_IWDG               FALSE
#if !defined(DRIVER_USE_TIMCAP) || defined(__DOXYGEN__)
#define DRIVER_USE_TIMCAP              FALSE
#if !defined(DRIVER_USE_IUART) || defined(__DOXYGEN__)
//COMMENT OUT BY CC++
//#define DRIVER_USE_IUART              TRUE
//COMMENT OUT BY CC--
#define DRIVER_USE_IUART              FALSE
#if !defined(DRIVER_USE_EICU) || defined(__DOXYGEN__)
#define DRIVER_USE_EICU                FALSE
#if !defined(DRIVER_USE_EEPROM) || defined(__DOXYGEN__)
#define DRIVER_USE_EEPROM              FALSE
 * DAC driver system settings.
#define STM32_DAC_USE_CHN1                  TRUE
//add by cc+
#define STM32_HAS_DAC_CHN1                  TRUE
//add by cc-
#define STM32_DAC_CHN1_IRQ_PRIORITY         10
#define STM32_DAC_CHN1_DMA_PRIORITY         2
#define STM32_DAC_DMA_ERROR_HOOK(dacp)      chSysHalt()
#define STM32_DAC_CHN1_DMA_STREAM           STM32_DMA_STREAM_ID(1, 3)
//removed by cc++
//#define STM32_DAC_USE_CHN2                  FALSE
//removed by cc--
//add by cc++
//add by cc--
#define STM32_DAC_CHN2_IRQ_PRIORITY         10
#define STM32_DAC_CHN2_DMA_PRIORITY         2
#define STM32_DAC_CHN2_DMA_STREAM           STM32_DMA_STREAM_ID(1, 4)
 * TIMCAP driver system settings.
#define STM32_TIMCAP_USE_TIM1                  FALSE
#define STM32_TIMCAP_USE_TIM2                  FALSE
#define STM32_TIMCAP_USE_TIM3                  FALSE
#define STM32_TIMCAP_TIM1_IRQ_PRIORITY         2
#define STM32_TIMCAP_TIM2_IRQ_PRIORITY         2
#define STM32_TIMCAP_TIM3_IRQ_PRIORITY         2
 * IUART driver system settings.
#define STM32_IUART_USE_USART1             FALSE
#define STM32_IUART_USE_USART2             FALSE
#define STM32_IUART_USART1_IRQ_PRIORITY      3
#define STM32_IUART_USART2_IRQ_PRIORITY      3
 * Extended ICU driver system settings.
#define STM32_EICU_USE_TIM1                 FALSE
#define STM32_EICU_USE_TIM2                 FALSE
#define STM32_EICU_USE_TIM3                 FALSE
#define STM32_EICU_USE_TIM4                 FALSE
#define STM32_EICU_USE_TIM5                 FALSE
#define STM32_EICU_USE_TIM8                 FALSE
#define STM32_EICU_USE_TIM9                 FALSE
#define STM32_EICU_USE_TIM12               FALSE
#define STM32_EICU_TIM1_IRQ_PRIORITY        3
#define STM32_EICU_TIM2_IRQ_PRIORITY        3
#define STM32_EICU_TIM3_IRQ_PRIORITY        3
#define STM32_EICU_TIM4_IRQ_PRIORITY        3
#define STM32_EICU_TIM5_IRQ_PRIORITY        3
#define STM32_EICU_TIM8_IRQ_PRIORITY        3
#define STM32_EICU_TIM9_IRQ_PRIORITY        3
#define STM32_EICU_TIM12_IRQ_PRIORITY      3
 * EEPROM driver system settings.
#define EEPROM_DRV_USE_25XX              FALSE
#define EEPROM_DRV_USE_24XX              FALSE
#define EEPROM_DRV_TABLE_SIZE           2
#endif /* DRIVERS_CONF_H_ */
Posted: Wed Jan 21, 2015 2:37 pm
by deeznutz
I get the following error when linking:
Linking build/ch.elf
build/obj/dac_lld.o: In function `dac_lld_init':
C:\ChibiStudio\workspace26\STM32F4xx-DAC-Test/../../ChibiOS-Drivers/stm32/dac_lld.c:138: undefined reference to `_stm32_dma_streams'
Any ideas?
Thanks!
Nils
Posted: Wed Jan 21, 2015 3:09 pm
by mobyfab
Try to enable any driver that uses DMA, like SPI.
It's a bug in the DAC driver. (there is no way to force DMA unless you use macros inside the HAL)
Posted: Wed Jan 21, 2015 3:18 pm
by deeznutz
Hmm, strange, the error changed... not sure what I have changed in the meantime...
`chThdExit' referenced in section `.text._port_thread_start.4322' of C:\Users\OSSENB~1.FB1\AppData\Local\Temp\cc8fCAza.ltrans0.ltrans.o: defined in discarded section `.text' of build/obj/chthreads.o (symbol from plugin)
C:\Users\OSSENB~1.FB1\AppData\Local\Temp\cc8fCAza.ltrans0.ltrans.o: In function `_trace_init':
C:\ChibiStudio\workspace26\STM32F4xx-DAC-Test/../../chibios/os/kernel/src/chdebug.c:231: undefined reference to `_stm32_dma_streams'
make: *** [build/ch.elf] Error 1
I have no idea what's going on...
Posted: Wed Jan 21, 2015 3:27 pm
Are you mixing files from 2.6 and 3.0? make sure that all the configuration files and the makefile come from the version you are actually using.
Posted: Wed Jan 21, 2015 3:30 pm
by deeznutz
Thanks for your comments. Error "undefined reference to `_stm32_dma_streams'" dissapeared after enabling SPI as Mobyfab recommended. I think I have messed up something else... I will try to restart from scratch and see if I can get it running...
Posted: Wed Jan 21, 2015 4:33 pm
by deeznutz
Ok, a step further... DAC works with dacConvert(&DACD1,dac_value);
@Mobifab: Do you have an example for a simple sinewave -or whatever- DMA application? Tried this http://forum.chibios.org/phpbb/viewtopic.php?f=16&t=2274&sid=922760ebe0bec88e6f3bf751c592bbfa#p18358 one without success (even when stripped down to one channel)? Thank you in advance!
Cheers
Nils
