Page 1 of 2
STM32F429I-Disco with SDCard
Posted: Mon Feb 23, 2015 4:37 pm
by kiwi
Hello guys,
I'am fairly new to the whole micro controller programming except for some experience with Arduino and so far I have managed to build the stm32f429i-disco demo application as well as chibiOS with uGFX.
I've builded these sample applications Linux with make + vi.
The following questions I have for you are rather basic, but I really would appreciate some clarifications because I'm rather confused.
Ok, I want to connect a SDCard to my stm32f429, I guess I will have to use SPI for that, right?
To which ports do I have to connect my card?
I read through the official board manual and the documentation I could find but still I don't know to which ports on the board I have to connect my SDcard. Is there a document describing the properties of the ports? Something like 'you can use PA7 for SPI and I2C' and I can then choose which of the ports I use for what or is the function of a port statically defined (e.g. PA7 is SPI1 CS)?
Or can I use every free port for SPI connection as long as nothing else is using it for communication?
I would appreciate it if you could point me in the right direction.
thanks,
kiwi
Re: STM32F429I-Disco with SDCard
Posted: Mon Feb 23, 2015 4:39 pm
ChibiOS has both the driver for cards attached via SPI (MMC_SPI) and an SDC driver that uses the SDIO peripheral, you can use any of those. for MMC_SPI you can use any SPI port.
Posted: Mon Feb 23, 2015 5:56 pm
by Tectu
If you're interested: As soon as your SD card is working inside of the ChibiOS/RT framework you can use the GFILE module of the uGFX library to easily handle your files. Most uGFX items provide a highlevel GFILE API that makes it super easy to display images, save and restore calibration data etc.
Posted: Mon Feb 23, 2015 6:04 pm
by kiwi
thanks so far. But it's still confusing for me which of the ports of the STM32F429i-disco is an SPI or SDIO port?
I can't find anything in the documentation provided here
http://www.st.com/web/catalog/tools/FM116/SC959/SS1532/PF259090.
Or do I have to configure the ports somwhere?
EDIT:
@tecu that is exactly where I want to go, but so far I think I'm lacking basic knowledge to connect and setup my SDCard properly.
best,
kiwi
Posted: Mon Feb 23, 2015 6:22 pm
by Tectu
When you decide to use SDIO (which I highly recommend as it is the standard) then you don't have a choice. There is only one set of SDC pins on the STM32. When you want to use SPI you can use any of the SPI peripherals.
In the datasheet of the microcontroller that you are using (
http://www.st.com/st-web-ui/static/acti ... 071990.pdf) you can see on page 76 that the corresponding pins are PC8 to PC12 and PD2. All of them need to be configured as AF12.
Posted: Mon Feb 23, 2015 7:11 pm
Pin assignments are described in the STM32 DataSheet (not the Reference Manual). You can configure them by editing board.h. See the board files of the Olimex STM32-E407 board for an example.
Posted: Wed Feb 25, 2015 7:38 pm
by kiwi
I connected my SDCard to the pins for SDIO mentioned in the datasheet and wrote a little test to check whether I'am able to write to the SDcard but according to
gdb f_open returns
FR_NOT_READY.
Can you tell me whether my code is correct or if I miss configured the board.h?
Here is the main.c and I put the board.h on gist.github.com:
https://gist.github.com/bigzed/eaa8beb9e121321d5b98thanks a lot,
kiwi
#include "ch.h"
#include "hal.h"
/* FatFS */
#include "ff.h"
#include "main.h"
FATFS SDC_FS;
/* SDCDriver config. */
static SDCConfig sdccfg = {0};
int main(void)
/* Initialize SDCard over SDIO */
sdcObjectInit(&SDCD1);
sdcStart(&SDCD1, &sdccfg);
if(sdcConnect(&SDCD1)) {
if(f_mount(0, &SDC_FS) == FR_OK) {
FIL file;
UINT written;
if(f_open(&file, "test.txt", FA_CREATE_ALWAYS) == FR_OK) {
f_write(&file, (void*)"a", 8, &written);
f_close(&file);
while(TRUE) {
chThdSleepMilliseconds(500);
return 1;
Posted: Wed Feb 25, 2015 7:42 pm
sdcConnect() returns true in case of errors, you are writing after the connection failed.
Posted: Wed Feb 25, 2015 7:56 pm
by kiwi
Ok, but shouldn't this mean I configured the pins incorrectly?
Here is a diff of my board.h to configure the pins PC8-PC12 and PD2 as AF12. Is this correct at all?
Sorry for the basic questions.
-#define VAL_GPIOC_AFRH (PIN_AFIO_AF(GPIOC_PIN8, 0) | \
- PIN_AFIO_AF(GPIOC_I2C3_SDA, 4) | \
- PIN_AFIO_AF(GPIOC_LCD_R2, 14) | \
- PIN_AFIO_AF(GPIOC_PIN11, 0) | \
- PIN_AFIO_AF(GPIOC_PIN12, 0) | \
+#define VAL_GPIOC_AFRH (PIN_AFIO_AF(GPIOC_PIN8, 12) | \
+ PIN_AFIO_AF(GPIOC_I2C3_SDA, 12) | \
+ PIN_AFIO_AF(GPIOC_LCD_R2, 12) | \
+ PIN_AFIO_AF(GPIOC_PIN11, 12) | \
+ PIN_AFIO_AF(GPIOC_PIN12, 12) | \
PIN_AFIO_AF(GPIOC_PIN13, 0) | \
PIN_AFIO_AF(GPIOC_OSC32_IN, 0) | \
PIN_AFIO_AF(GPIOC_OSC32_OUT, 0))
@@ -688,7 +688,8 @@
PIN_AFIO_AF(GPIOD_PIN5, 0) | \
PIN_AFIO_AF(GPIOD_LCD_B2, 14) | \
PIN_AFIO_AF(GPIOD_PIN7, 0))
-#define VAL_GPIOD_AFRH (PIN_AFIO_AF(GPIOD_FMC_D13, 12) | \
+#define VAL_GPIOD_AFRH (PIN_AFIO_AF(GPIOD_PIN2, 12) | \
+ PIN_AFIO_AF(GPIOD_FMC_D13, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D14, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D15, 12) | \
PIN_AFIO_AF(GPIOD_LCD_TE, 0) | \
Posted: Wed Feb 25, 2015 8:16 pm
For an example of SDC pin configuration give a look to the Olimex boards with F4 devices, for example the STM32-E407, if your board use the same pins you can copy the configuration from there.
