Hello world, Nucleo ADC
nopxor
Post by nopxor »
Hi everybody,
I have just discovered ChibiOS and I begin to test it with my Nucleo boards (F103RB & F401RE).
Very cool indeed ! Congratulation Giovanni. Great and elegant. The concept is very interesting.
Thanks a lot for sharing.
I have tested Serial, PWM, Events, Shell and ADC with success.
ADC is a little tedious to configure for beginners.
If it can help, here is a little example from the good software of Mathias & Resset here:
https://github.com/resset/STM32F4-Disco ... ample-code
 * @file ChibiOS_3/myprogsNucleoF401RE/ADC2/main.c
 * @brief buttonUser on => ADC (single) conversion on PC5 pin (send on serial terminal via USB)
 * @details error at compilation with chprintf.h. It was not in ../os/hal/include
 *  and no more in ../os/various. Copy it from /os/hal/lib/streams and add to Makefile:
 * $(CHIBIOS)/os/hal/lib/streams/chprintf.c (line 105)
 * In order to use the PAL driver the HAL_USE_PAL option must be enabled in halconf.h.
 * You must enable too, the ADC subsystem in halconf.h
 * In mcuconf.h, set:
 * STM32_ADC_USE_ADC1       TRUE
 * STM32_SERIAL_USE_USART2    TRUE
#include "ch.h"
#include "chprintf.h"
 * Defines for single scan conversion
#define ADC_GRP1_NUM_CHANNELS   1
#define ADC_GRP1_BUF_DEPTH      2048*2*4
 * Buffer for single conversion
static adcsample_t samples1[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
 * ADC conversion group.
 * Mode:        Linear buffer, 8 samples of 1 channel, SW triggered.
 * Channels:    IN15 = PC5 = Morpho Nucleo CN10-pin 6.
static const ADCConversionGroup adcgrpcfg1 = {
  FALSE,                                 // circular buffer mode
  ADC_GRP1_NUM_CHANNELS,                 // Number of the analog channels
  NULL,                                  // Callback function (not needed here)
  NULL,                                // Error callback
  0,                                     // CR1
  ADC_CR2_SWSTART,                       // CR2
  ADC_SMPR1_SMP_AN15(ADC_SAMPLE_3),      // sample times ch10-18
  0,                                     // sample times ch0-9
  ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),// SQR1: Conversion group sequence 13...16 + sequence length
  0,                                     // SQR2: Conversion group sequence 7...12
  ADC_SQR3_SQ1_N(ADC_CHANNEL_IN15)       // SQR3: Conversion group sequence 1...6
int main(void) {
  * ADC init
  palSetPadMode(GPIOC, GPIOC_PIN5, PAL_MODE_INPUT_ANALOG);
  adcStart(&ADCD1, NULL);
   * Activates the serial driver 2 using the driver default configuration:
   * 38400 bauds, 8bits, 1 stop-bit, no parity
  sdStart(&SD2, NULL);
   * sleeping in a loop and check the button state.
  while (TRUE)
    if (!palReadPad(GPIOC, GPIOC_BUTTON)){       // user button pushed
 * single analog conversion
 * converts ADC_GRP1_BUF_DEPTH samples and averages them
 * with ADC_GRP1_BUF_DEPTH==2048 this gives around 14 bit precision
 * even though the ADC hardware has only 12 bits internal precision
 * also at 2048 samples the 14 bit are nearly noise free, while
 * each sample is very noisy.
 * WARNING: If you average to many samples, the variable containing
 *  the sum may overflow. That means that your readings will be wrong.
 * However: With the ADC delivering a max value of 2^12, with uint32_t
 *  you can average 2^20 = 1048576 samples.
  uint32_t sum=0;
  unsigned int i;
  adcConvert(&ADCD1, &adcgrpcfg1, samples1, ADC_GRP1_BUF_DEPTH);
  //prints the first measured value
  chprintf((BaseSequentialStream *)&SD2, "Measured: %d  ", samples1[0]*16);
  sum=0;
  for (i=0;i<ADC_GRP1_BUF_DEPTH;i++){
      sum += samples1[i];
  //prints the averaged value with two digits precision
  chprintf((BaseSequentialStream *)&SD2, "%U\r\n", sum/(ADC_GRP1_BUF_DEPTH/16));
  chThdSleepMilliseconds(500);
Re: Hello world, Nucleo ADC
The configuration of the peripheral is usually the hard part, knowledge of the Reference Manual is required. This is going to improve during next year, we are going to introduce a visual configuration tool and the configuration code will be generated.
nopxor
Post by nopxor »
Good idea :idea:
