Problem with chThdSleepSeconds() STM32F407
MySOL
Post by MySOL »
Hello gentelmens! Really need your help. I studied CHIBIOS and now there is a problem with the function call chThdSleepMilliseconds(). Actually, it works fine, as in the main thread, and in the simple regular threads (like led blinking). But now there was a need revival thread on the external interrupt. I used the example that comes with the OS in the test folder and examples of site. There is my code
static void extcb1(EXTDriver *extp, expchannel_t channel) {
  (void)extp;
  (void)channel;
  chSysLockFromIsr();
  palSetPad(GPIOD, GPIOD_LED5);    // red led
   chSchReadyI(tp);
   tp=NULL;
  chSysUnlockFromIsr();
    {EXT_CH_MODE_BOTH_EDGES | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, extcb1},
    {EXT_CH_MODE_DISABLED, NULL},
static WORKING_AREA(waThread1, 256);
  (void)arg;
   tp=chThdSelf();
   chSysLock();
   chSchGoSleepS(THD_STATE_SUSPENDED);
   chSysUnlock();
  while (TRUE) {
    palSetPad(GPIOD, GPIOD_LED3);       /* Orange.  */
    chThdSleepSeconds(1);
    palClearPad(GPIOD, GPIOD_LED3);     /* Orange.  */
 * Application entry point.
int main(void) {
  uint8_t i;
   palSetPadMode(GPIOD, GPIOD_LED4, PAL_MODE_OUTPUT_PUSHPULL);
   palSetPadMode(GPIOD, GPIOD_LED3, PAL_MODE_OUTPUT_PUSHPULL);
  extStart(&EXTD1, &extcfg);
   while (TRUE)
   palSetPad(GPIOD, GPIOD_LED4);       /* Green.  */
    palClearPad(GPIOD, GPIOD_LED4);     /* Green.  */
After reset "Green led" is blinking. After external interrupting green flashing stops and the orange LED lights up , but does not blink. From this I concluded that the system is hung on the process chThdSleepSeconds(1) from the tread. Rly dont know what to do. Please help. Thank you!
Re: Problem with chThdSleepSeconds() STM32F407
Several problems there, try this:
  (void)extp;
  (void)channel;
  chSysLockFromIsr();
  if (tp != NULL) {  // You need to check if the thread entered the suspended state
   chSchReadyI(tp);
   tp=NULL;
  (void)arg;
  chSysLock();
  tp=chThdSelf(); // This must go inside the critical zone
  chSysUnlock();
  while (TRUE) {
For this kind of things it is better to use binary semaphores anyway: chBSemSignalI() from the callback, chBSemWait() from the thread, the semaphore is initialized as "taken".
MySOL
Post by MySOL »
Perfectly working! Thank you for your help and please forgive me for concern=)
