I want to receive some data via the serial driver and ChibiOS 2.6.6 using an Olimex STM32E407 development board. The sender of the serial data is EnOcean Pi, which is connected to 3,3V, GND, RX and TX. TX of Sender is connected to PD6 (USART2 RX) and RX of sender is connected to PD5 (USART2 TX). I configured PD5 and PD6 in board.h file like USART6 (based on lwip example on Olimex STM32-E407) but using PD5 and PD6 and alternate 7 (which is alternate for USART2, USART6 has alternate 8). In halconf.h I enabled
#define HAL_USE_SERIAL TRUE
and in mcuconf.h i enabled USART2
#define STM32_SERIAL_USE_USART2 TRUE
The SD2 is started as following:
SerialConfig usartconfig;
usartconfig.speed=57600;
sdStart(&SD2, &usartconfig);
In documentation of Enocean Pi, they use a bitrate of 58823, but they write also, that 57600 should work. However, some of my experiments used 58800 and 58823 bit.
When I send a radio telegram to the Enocean Pi, the TX pin of it emits some toggling (I connected the TX-Pin for some tests to PD0 and read it using palReadPad(GPIOD,GPIOD_PIN0);), so i assumed, that this is the data I want. But the input queue of SD2 (tested with qspace = chQSpaceI(&(&SD2)->iqueue);) stayed empty and reading with sdRead(&SD2, (uint8_t*)&cha, 1); blocked (which is no miracle, if input queue is empty).
So I wrote a byte to SD2 and bing! the input queue contains a byte, which i can read with sdRead(). I had expected, that the byte would be written to the output queue (which qspace stays 64, means no byte in there). So I assume i forgot somewhere to connect the iqueue with the USART2 RX and the oqueue with the USART2 TX.
Same game if i use SD6 and the corresponding pins.
Ok, how can i connect the TX of sender with the iqueue of SD2?
Thank you very much in advance,
Dirk.
