Failed to compile usb_lld.c in Keil
daemon
Post by daemon »
Hello!
The last stable version 2.6.7 and unstable version 2.6.8 has the same compilation error in Keil MDK 5:
compiling usb_lld.c...
os\hal\platforms\STM32\OTGv1\usb_lld.c(539): warning: #111-D: statement is unreachable
__set_BASEPRI(0);
os\hal\platforms\STM32\OTGv1\usb_lld.c(1266): error: #268: declaration may not appear after executable statement in block
uint32_t pcnt = (isp->txsize + usbp->epc[ep]->in_maxsize - 1) /
os\hal\platforms\STM32\OTGv1\usb_lld.c: 1 warning, 1 error
NOTE: STM32_USB_OTGFIFO_FILL_BASEPRI was defined in mcuconf.h
"uint32_t pcnt" must be defined at the start of a function. (Its not a C++ code :D )
Another issue is that __set_BASEPRI(0); is unreachable in the code and it (seems) to hang the system when STM32_USB_OTGFIFO_FILL_BASEPRI is not 0.
GunterO
Re: Failed to compile usb_lld.c in Keil
Post by GunterO »
I think you need to enable the -C99 option in µVision.
The error "declaration may not appear after executable statement in block" is typical when the support for the ISO C99 standard is not enabled.
daemon
Post by daemon »
Yes, you are right. The question arise because this was the only one place in the code with such error. Maybe because ChibiOS is ANSI C compliant.
Other question regarding __set_BASEPRI(0); is still actual.
I forgot about this, it is misplaced, will fix in next version.
daemon
Post by daemon »
OK, thanks Giovanni!
