cygwin build
Posted: Mon Mar 16, 2015 12:07 pm
by JoVM
Is anyone building under cygwin? I use 'sed' to change the 'c:' path from the deps. Anyone has a 'rule' file that handle this straight away?
Re: cygwin build
Posted: Wed Mar 18, 2015 8:12 am
by Tectu
I'm using Cygwin (64-Bit version) without any problems at all. I never had to do any manual hacking at all and everything worked out of the box so far.
Why do you want to modify the path to C:\ ?
Re: cygwin build
Posted: Wed Mar 18, 2015 9:14 am
The makefiles should work without changes.
Re: cygwin build
Posted: Wed Mar 18, 2015 2:17 pm
by JoVM
The discomfort of building under cygwin is that it put path names of dependencies in this form c:\program\ files\gcc-arm-none-eabi-4_9-2014
At rebuild make sees this c: as a target. You can see in your .d files cygdrive/c/ then no problems.
Re: cygwin build
Posted: Tue Jun 30, 2015 7:30 am
by JoVM
Tectu wrote:I'm using Cygwin (64-Bit version) without any problems at all. I never had to do any manual hacking at all and everything worked out of the box so far.
Depends on the cygwin configuration of the machine you cross-compile with.
