Hello.
I do not understand how initialized pointer ep0next and size ep0n the exchange via USB.
file usb.c line 682: usbPrepareReceive (usbp, 0, usbp-> ep0next, usbp-> ep0n);
Needs to receive data in a custom application HID.
user-defined function bool_t hidRequestsHook (USBDriver * usbp);
data from: case HID_SET_REPORT_REQUEST: ... return TRUE;
Thank you.
usb.c ep0 buffer manipulation
Re: usb.c ep0 buffer manipulation
I don't understand your question well.
About usbPrepareReceive():
param 1: USB driver pointer
param 2: the endpoint number
param 3: pointer to a buffer where to put data (you decide this)
param 4: number of bytes to receive
You don't need to use ep0n and ep0next, those are part of the state machine handling EP0.
your original code file usb.c line 682: usbPrepareReceive (usbp, 0, usbp-> ep0next, usbp-> ep0n);
use usbp-> ep0next pointer and usbp-> ep0n.
1) How you initialized pointer ep0next and size ep0n ( original inside Chibios in this part)?
2) There is a custom callback at the end of the actual data reception?
3) I had to edit usb.c to retrieve data. There is a way without editing?
About 1 and 2:
About 3, you don't need to modify usb.c, you need to implement a custom message handler for the EP0. This is done using an hook callback.
First "requests" is invoked, you need to check in that handler if it is a message that you need to handle, if so then return "true", by returning "false" the default messages handler is called, it manages the normal EP0 messages.
About 1 and 2:
* @brief Request transfer setup.
* @details This macro is used by the request handling callbacks in order to
* prepare a transaction over the endpoint zero.
* @param[in] usbp pointer to the @p USBDriver object
* @param[in] buf pointer to a buffer for the transaction data
* @param[in] n number of bytes to be transferred
* @param[in] endcb callback to be invoked after the transfer or @p NULL
* @api
#define usbSetupTransfer(usbp, buf, n, endcb) { \
(usbp)->ep0next = (buf); \
(usbp)->ep0n = (n); \
(usbp)->ep0endcb = (endcb); \
/* First verify if the application has an handler installed for this
request.*/
if ((usbp->config->requests_hook_cb == NULL) ||
!(usbp->config->requests_hook_cb(usbp))) {
/* Invoking the default handler, if this fails then stalls the
endpoint zero as error.*/
if (((usbp->setup[0] & USB_RTYPE_TYPE_MASK) != USB_RTYPE_TYPE_STD) ||
!default_handler(usbp)) {
