External Interrupts
ChibiOS public support forum for topics related to the STMicroelectronics SPC56x family of automotive micro-controllers.
GianlucaLaManna
External Interrupts
Postby GianlucaLaManna » Mon Apr 27, 2015 7:45 pm
I have this ultrasonic sensor(HY-SRF05 blue).
I have to manage 3 of this sensors simultaneously. I have the board SPC560P-DISP.
My code is this:
palClearPad(PORT_A, TRIG_PIN);
osalThreadSleepMicroseconds(2);
palSetPad(PORT_A, TRIG_PIN);
osalThreadSleepMicroseconds(10);
The datasheet says use a pulse at 10us and then measure Rising Edge / Falling Edge. But how?
Maybe with some interrupt. But I don't know how works on my board.
I'm using this code for my handle interruption:
#define INTERRUPT vector43
OSAL_IRQ_HANDLER(INTERRUPT) {
  OSAL_IRQ_PROLOGUE();
  OSAL_IRQ_EPILOGUE();
I don't know if it's correct.
Best regards,
Gianluca.
Has thanked: 1118 times
Been thanked: 938 times
Re: External Interrupts
Postby Giovanni » Mon Apr 27, 2015 9:58 pm
All sleep functions round the specified time to the rick resolution. System tick is 1mS so you can't sleep 10 microseconds using those functions. For such small delays you need to use a software loop delays or a physical timer.
If you need to measure pulses then you may use the ICU driver.
GianlucaLaManna
Postby GianlucaLaManna » Tue Apr 28, 2015 8:29 am
Ok, I will try with ICU drivers temporarily.
Best regards,
Gianluca.
Return to “SPC56x Support”
