Porting Difficulties (Newbie)
Posted: Mon Jun 15, 2015 4:53 pm
Hi, I'm trying a port of the Stellaris to ChibiOS 3.0.0 (previously there was a port on 2.5.0, but I want to learn about porting in preparation for getting a new board). I copied from another platform as advised, crafted some files, but I got stuck with some error messages.
First, some implicit function errors
(and similar), though I had defined this function in pal_lld.c in my os/hal/ports/STELLARIS directory. I'm able to circumvent this by adding extern statements, but I know this is the wrong thing to do -- because it would mean modifying pal.c for example. So it's probably something incorrect or missing in a makefile?
Second, even after adding such extern statements to see what would happen, the make of a demo fails with
make:
An example of the attempted make is shown below
unable to find _pal_lld_writegroup
make:
*** No rule to make target `build/ch.elf', needed by `all'. Stop.
user@dhcp:/arm/home/user/ChibiOS-3.0.0/demos/STELLARIS$ make clean
Cleaning
rm -fR .dep build
Done
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m4 -O2 -ggdb -fomit-frame-pointer -falign-functions=16 -ffunction-sections -fdata-sections -fno-common -flto -Wall -Wextra -Wstrict-prototypes -Wa,-alms=build/lst/ -DCORTEX_USE_FPU=FALSE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -MD -MP -MF .dep/build.d -I. -I../../os/common/ports/ARMCMx/devices/STELLARIS -I../../os/ext/CMSIS/include -I../../os/ext/CMSIS/STELLARIS -I../../os/rt/include -I../../os/rt/ports/ARMCMx -I../../os/rt/ports/ARMCMx/compilers/GCC -I../../os/hal/osal/rt -I../../os/hal/include -I../../os/hal/ports/common/ARMCMx -I../../os/hal/ports/STELLARIS -I../../os/hal/boards/STELLARIS -I../../test/rt -I../../os/various main.c -o main.o
Compiling crt0_v7m.s
Compiling chcoreasm_v7m.s
Compiling crt1.c
Compiling vectors.c
Compiling chsys.c
Compiling chdebug.c
Compiling chvt.c
Compiling chschd.c
Compiling chthreads.c
Compiling chdynamic.c
Compiling chregistry.c
Compiling chsem.c
Compiling chmtx.c
Compiling chcond.c
Compiling chevents.c
Compiling chmsg.c
Compiling chmboxes.c
Compiling chqueues.c
Compiling chmemcore.c
Compiling chheap.c
Compiling chmempools.c
Compiling chcore.c
Compiling chcore_v7m.c
Compiling osal.c
Compiling hal.c
Compiling st.c
Compiling hal_queues.c
Compiling hal_mmcsd.c
Compiling pal.c
../../os/hal/src/pal.c: In function 'palWriteBus':
../../os/hal/src/pal.c:99:3: warning: implicit declaration of function '_pal_lld_writegroup' [-Wimplicit-function-declaration]
palWriteGroup(bus->portid, bus->mask, bus->offset, bits);
Compiling nvic.c
Compiling hal_lld.c
Compiling pal_lld.c
Compiling board.c
Compiling test.c
Compiling testthd.c
Compiling testsem.c
Compiling testmtx.c
Compiling testmsg.c
Compiling testmbox.c
Compiling testevt.c
Compiling testheap.c
Compiling testpools.c
Compiling testdyn.c
Compiling testqueues.c
Compiling testsys.c
Compiling testbmk.c
Compiling main.c
main.c: In function 'Thread1':
main.c:31:7: warning: implicit declaration of function '_pal_lld_writepad' [-Wimplicit-function-declaration]
palClearPad(GPIOF, GPIOF_LED_RED);
make: *** No rule to make target `build/ch.elf', needed by `all'. Stop.
