STM32F4 Floating Point Operations do not work
IgorEE
Post by IgorEE »
I'm hoping someone can help me out as two days have passed and I am not capable of solving the issue myself. Hopefully it is something simple.
I can not perform any operations using float values. They just don't work or produce completely wrong results. As an example, I added the following shell function to the standard STM32F4-Discovery-MEMS demo:
static void cmd_float(BaseSequentialStream *chp, int argc, char *argv[]) {
  float res, res1, res2, res3;
  res = (float)2.2/(float)1.1;
  res1 = (float)2.3+(float)3.4;
  res2 = (float)3.3-(float)5.2;
  res3 = (float)3.4*(float)8.5;
  chprintf(chp, "Result of float division: %f\r\n", res);
  chprintf(chp, "Result of float addition: %f\r\n", res1);
  chprintf(chp, "Result of float subtraction: %f\r\n", res2);
  chprintf(chp, "Result of float multiplication: %f\r\n", res3);
and the output when calling this shell command is:
Result of float division: f
Result of float addition: f
Result of float subtraction: f
Result of float multiplication: f
Which is quite strange.
I tried setting USE_FPU in the Makefile to no,hard,softfp but nothing changes. Using just "soft" produces a compile error.
Can anyone shed some light on what needs to be done to use floats correctly? This is in ChibiStudio latest I believe, Chibios 2.6 branch.
Any help appreciated,
Thanks in advance,
-Igor
Re: STM32F4 Floating Point Operations do not work
hi,
chprintf() does not support float unless you enable it, see the definitions in the header. It is printing the f of %f.
IgorEE
Post by IgorEE »
Thanks Giovanni,
Got it!
-Igor
