How to generate HF clock output?
Posted: Mon Aug 10, 2015 7:05 am
by ceremcem
We are using ChibiOS STM32F407 Discovery Board (8Mhz XTAL) to generate a relatively high frequency output (500 kHz) with the following code:
    static void squareWave(void *arg)
        /* PB0 will be used for square wave
            use AlternateFunction.0 for digital io
        palSetPadMode(GPIOB, 0, PAL_MODE_ALTERNATE(0));
       palSetPadMode(GPIOB, 0, PAL_MODE_OUTPUT_PUSHPULL);
        while(true)
            palSetPad(GPIOB, 0);
            chThdSleepMicroseconds(1);
            palClearPad(GPIOB, 0);
But the result is 10 kHz or so. What do we do wrong?
Edit
if `#define CH_CFG_ST_FREQUENCY 10000` remains in `chconf.h`, it does produce a 10 kHz output. When we change that value from 10000 to 1000000, it gives just about 100 kHz (99.8 kHz or so), but not 500 kHz. Also,
Re: How to generate HF clock output?
Posted: Mon Aug 10, 2015 7:22 am
What version are you using?
For that kind of things better use the PWM driver anyway.
Posted: Thu Aug 27, 2015 2:21 pm
by ceremcem
I'm using ChibiOS-3.x. Regarding to your suggestion, I wrote a simple variable frequency PWM generator:
https://github.com/ceremcem/chibi-test/ ... 282/main.c
It's dirty but it works.
Thank you for leading.
Note: I was not aware of your answer. Fixed this in the notification settings. Anyway, I'm sorry for the late response.
Posted: Thu Aug 27, 2015 2:24 pm
I forgot to mention, there are also the MCO1 and MCO2 pins that can output any internal clock source. Depending on the frequency you need you may also consider them.
Posted: Thu Aug 27, 2015 11:53 pm
by ceremcem
As per question, that would be a sensible option, but I omitted to say that I needed that kind of variable frequency. Since I was pretty sure about the code block that generates the squarewave, I thought I might change the sleep time as I wish at the end of this issue, but pwm driver does exacly what I would :)
