chMBPost is hanging STM32F429iDiscovery
0st3n
Post by 0st3n »
I have connected my discovery to an external phy (LAN8720). I have removed everything else which was connected to the pins (LCD, MEMS, usb OTG).
I now having some troubles with the LWIP stack. When i try to make a new netconn_new(NETCONN_TCP) object, it hangs in some of the lwip bindings for chibios.
void sys_mbox_post(sys_mbox_t *mbox, void *msg) {
  chMBPost(*mbox, (msg_t)msg, TIME_INFINITE);
i have called the tcpip_init(NULL,NULL); function before i trying to create the new netconn.
Anyone who have any ideas of what could be wrong ?
Re: chMBPost is hanging STM32F429iDiscovery
What ChibiOS version are you using? this is likely an initialization order issue, the mailbox is used before it is initialized.
In 3.0.1 there is a new initialization method that should avoid that issue.
0st3n
Post by 0st3n »
Giovanni wrote:Hi,
It's the version 3.0.1. Witch init function should i use for having the LWIP stack / bindings to create the right mailbox init ?
Look at the RT-STM32F407-OLIMEX_E407-LWIP-FATFS-USB demo.
There is a single lwipInit(NULL); function to call.
0st3n
Post by 0st3n »
Thanks, now i got the network working, and able to send udp broadcast.
I have copied the lwipopts.h from the demo project you referred to.
But even after i called the
lwipInit(NULL);
then i'm not able to ping the board. It doesn't seem to answer on the ARP requests. Do you know what could be wrong now ? or should there bee some different setup in the lwipopts.h file for the STM32F429 ?
Not sure, I am able to ping that demo.
I am not a huge lwIP expert/user anyway :) I am more involved with RTOS-lwIP integration.
