Possible bug in I2C driver shifting adress.
7znakow
Post by 7znakow »
After some battle with stm32f4discovery board and built-in DAC(CS43l22) I disovered why I couldn't receive ACK signal. The problem was that everytime when I tried to make a transfer, address of device was shifted by 1 to the left (addr << 1) that's why DAC 0x94 addres became 0x128. I have discovered that by checking every adress from 0 to 255 and I found that transfer address was 0xA4 (0x94 >> 1). The solution to this problem was changing
i2cp->addr = (addr << 1);
to
i2cp->addr = (addr << 0);
in i2c_lld_master_transmit_timeout and i2c_lld_master_receive_timeout in lld drivers (i2c_lld.c) in I2Cv1 folder.
Can someone can tell me why address had to be shifted?
Re: Possible bug in I2C driver shifting adress.
The address is a 7 bits field, the LSb is used as RW flag, what you pass to the API is the value of the address field not the whole first byte.
This is done in order to be compatible with 10 bits addressing and because passing the R/W flag makes no sense (it is handled internally).
7znakow
Post by 7znakow »
Oh, yes compatibility, now that make sense. I've been looking only from 7 bit adress perspective.
