I am struggling with a microcontroller STM32F401re-Nucleo, I connected to the board temperature sensor DHT11 to calculate the temperature and humidity of a room, everything in amble of svilippo chibios.
So far, so good.
I find it difficult when I go to connect HD44780 LCD for viewing on the display.
This is the code:
PLAY Embedded demos - Copyright (C) 2014-2015 Rocco Marco Guglielmi
This file is part of PLAY Embedded demos.
#include "ch.h"
#include "lcd.h"
#include "chprintf.h"
/* LCD configuration */
static const PWMConfig pwmcfg = {
100000, /* 100kHz PWM clock frequency. */
100, /* PWM period is 1000 cycles. */
NULL,
{PWM_OUTPUT_ACTIVE_HIGH, NULL},
{PWM_OUTPUT_DISABLED, NULL},
0,
0
static const LCDConfig lcdcfg = {
{GPIOA, GPIOA_PIN4}, /* RS Port and pin */
{GPIOA, GPIOA_PIN1}, /* RW Port and pin */
{GPIOA, GPIOA_PIN0}, /* E Port and pin */
{GPIOC, GPIOC_PIN0},
{GPIOC, GPIOC_PIN1},
{GPIOC, GPIOC_PIN2},
{GPIOC, GPIOC_PIN3},
{GPIOC, GPIOC_PIN4},
{GPIOC, GPIOC_PIN5},
{GPIOC, GPIOC_PIN6},
{GPIOC, GPIOC_PIN7} /* Data Ports and pins */
{GPIOA, GPIOA_PIN8}, /* A Port and pin */
HD44780_EMS_Inc,
HD44780_DC_DisplayOn | HD44780_DC_CursorOff | HD44780_DC_BlinkingOff,
HD44780_Set_Font5x10Dots | HD44780_Set_2Lines | HD44780_Set_DataLenght8bit,
&PWMD1, /* PWM Driver for back-light */
&pwmcfg, /* PWM driver configuration for back-light */
0, /* PWM channel */
100, /* Back-light */
* Enable if your terminal supports ANSI ESCAPE CODE
#define ANSI_ESCAPE_CODE_ALLOWED TRUE
//static BaseSequentialStream * chp = (BaseSequentialStream*) &SD2;
/* DHT11 related defines */
* Width are in useconds
#define MCU_REQUEST_WIDTH 18000
#define DHT_ERROR_WIDTH 200
#define DHT_START_BIT_WIDTH 80
#define DHT_LOW_BIT_WIDTH 28
#define DHT_HIGH_BIT_WIDTH 70
/* ICU related code */
#define ICU_TIM_FREQ 1000000
static uint8_t TEMP, HR, CHECK_SUM, tmp, bit_counter = 0;;
static icucnt_t widths [40];
char* int2Char(int num, char* str, int base);
char* reverse(char* str, int dim_string);
char* reverse(char* str, int dim_string){
int pos_begin=0;
int pos_end=dim_string-1;
char temp;
while(pos_begin!=pos_end && pos_begin<pos_end){
temp=str[pos_begin];
str[pos_begin]=str[pos_end];
str[pos_end]=temp;
pos_begin=pos_begin+1;
pos_end=pos_end-1;
return str;
* Convert int to char
char* int2Char(int num, char* str, int base){
int i = 0;
bool isNegative = false;
/* Handle 0 explicitely, otherwise empty string is printed for 0 */
if (num == 0)
str[i++] = '0';
str[i] = '\0';
return str;
// In standard itoa(), negative numbers are handled only with
// base 10. Otherwise numbers are considered unsigned.
if (num < 0 && base == 10)
isNegative = true;
num = -num;
// Process individual digits
while (num != 0)
int rem = num % base;
str[i++] = (rem > 9)? (rem-10) + 'a' : rem + '0';
num = num/base;
// If number is negative, append '-'
if (isNegative)
str[i++] = '-';
str[i] = '\0'; // Append string terminator
// Reverse the string
reverse(str, i);
return str;
static void icuwidthcb(ICUDriver *icup) {
icucnt_t width = icuGetWidthX(icup);
if(width >= DHT_START_BIT_WIDTH){
/* starting bit resetting the bit counter */
bit_counter = 0;
else{
/* Recording current width. Just for fun */
widths[bit_counter] = width;
if(width > DHT_LOW_BIT_WIDTH){
tmp |= (1 << (7 - (bit_counter % 8)));
else{
tmp &= ~(1 << (7 - (bit_counter % 8)));
/* When bit_counter is 7, tmp contains the bit from 0 to 7 corresponding to
The Humidity Rate integer part (Decimal part is 0 on DHT 11) */
if(bit_counter == 7)
HR = tmp;
/* When bit_counter is 23, tmp contains the bit from 16 to 23 corresponding to
The Temperature integer part (Decimal part is 0 on DHT 11) */
if(bit_counter == 23)
TEMP = tmp;
/* When bit_counter is 39, tmp contains the bit from 32 to 39 corresponding to
The Check sum value */
if(bit_counter == 39)
CHECK_SUM = tmp;
bit_counter++;
static ICUConfig icucfg = {
ICU_INPUT_ACTIVE_HIGH,
ICU_TIM_FREQ, /* 1MHz ICU clock frequency. */
icuwidthcb,
NULL,
NULL,
ICU_CHANNEL_1,
0
/* Generic function */
* Red LED blinker thread, times are in milliseconds.
(void)arg;
while (true) {
if(TEMP >= 28){
palSetPad(GPIOA, GPIOA_LED_GREEN);
chThdSleepMilliseconds(500);
}else{
palClearPad(GPIOA, GPIOA_LED_GREEN);
* Application entry point.
int main(void) {
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
lcdInit();
* Activates the serial driver 2 using the driver default configuration.
sdStart(&SD2, NULL);
* Creates the blinker thread.
chThdSleepMilliseconds(1000);
palSetPadMode(GPIOA, GPIOA_PIN8, PAL_MODE_ALTERNATE(1));
palSetPadMode(GPIOA, GPIOA_PIN0, PAL_MODE_OUTPUT_PUSHPULL |
PAL_STM32_OSPEED_HIGHEST);
palSetPadMode(GPIOA, GPIOA_PIN1, PAL_MODE_OUTPUT_PUSHPULL |
palSetPadMode(GPIOA, GPIOA_PIN4, PAL_MODE_OUTPUT_PUSHPULL |
chThdSleepMilliseconds(100);
lcdStart(&LCDD1, &lcdcfg);
char valore_temperatura[3];
char valore_umidita[3];
int2Char(TEMP,valore_temperatura,10);
char temperatura[]="Temperatura :";
strcat(temperatura, valore_temperatura);
int2Char(HR, valore_umidita,10);
char umidita[]=" Umidita :";
strcat(umidita, valore_umidita);
//lcdWriteString(&LCDD1, " Umidita ",38);
chThdSleepMilliseconds(2000);
* sleeping in a loop and check the button state.
while (true) {
lcdWriteString(&LCDD1, temperatura, 0);
lcdWriteString(&LCDD1, umidita, 38);
* Making a request
palSetPadMode(GPIOA, GPIOA_PIN8, PAL_MODE_OUTPUT_PUSHPULL);
palWritePad(GPIOA, GPIOA_PIN8, PAL_LOW);
chThdSleepMicroseconds(MCU_REQUEST_WIDTH);
palWritePad(GPIOA, GPIOA_PIN8, PAL_HIGH);
* Initializes the ICU driver 1.
* GPIOA8 is the ICU input.
icuStart(&ICUD1, &icucfg);
icuStartCapture(&ICUD1);
icuEnableNotifications(&ICUD1);
chThdSleepMilliseconds(700);
/* #if ANSI_ESCAPE_CODE_ALLOWED
chprintf(chp, "\033[2J\033[1;1H");
icuStopCapture(&ICUD1);
icuStop(&ICUD1);
chprintf(chp, "Temperature: %d C, Humidity Rate: %d %% \n\r", TEMP, HR);
if(CHECK_SUM == (TEMP | HR)){
chprintf(chp, "Checksum OK!\n\r");
else{
chprintf(chp, "Checksum FAILED!\n\r");
strcpy(temperatura,"Temperatura :");
int2Char(HR,valore_umidita,10);
strcpy(umidita," Umidita :");
I hope that someone might give me some suggestions useful.
Thank you in advance.
