How to report a problem
Posted: Tue Dec 07, 2010 3:14 pm
This is a brief guideline about reporting problems:
- Search in the bug tracker and verify if the problem is already known, if so you may add your comments directly on the tracker.
- Describe briefly the problem then provide all the info that can help define the context: Target MCU, ChibiOS/RT version, compiler version, configuration, eventual customizations in the OS code etc.
- If possible provide a minimal code example that triggers the problem. It is a good idea to strip from your code everything is not strictly required to trigger the problem, this is the best way to have the problem fixed quickly.
