have you got the Nucleo32 boards running in Chibistudio and OpenOCD ?
if so what OpenOCD files did you use ? The ST-Link looks like it has two interfaces and thus will need to tell OCD which one to use
I have two F031K6 and F042K6 boards that im trying to get running.
Nucleo-32 boards
Re: Nucleo-32 boards
The OpenOCD contained in the current ChibiStudio is unable to use those devices (same problem here). I will include a patched one in the next release, I am able to build it myself now.
As soon it is done I will post it here first.
Rocco Marco just sent this to me, I will not be able to test it until weekend.
Giovanni wrote:stm32f0_stlink for both, under targets.
so no interface script ? i.e normally the it is setup like this
-c "telnet_port 4444" -f "interface/stlink-v2-1.cfg" -f "${file_prompt}"
Giovanni wrote:It would just give a warning but work anyway.
stm32f0_stlink is depredicated and says should not be used ???
can you copy and past your Arguments from the tool launch
