STM32F429 and sdcard
vahid4134
Post by vahid4134 »
I used testhal to test sdcard(SDIO). But fail on connecting.
I try to change Pal Model to
   palSetPadMode(GPIOC, 8, PAL_MODE_ALTERNATE(12));
   palSetPadMode(GPIOC, 9, PAL_MODE_ALTERNATE(12));
   palSetPadMode(GPIOC, 10, PAL_MODE_ALTERNATE(12));
   palSetPadMode(GPIOC, 11, PAL_MODE_ALTERNATE(12));
   palSetPadMode(GPIOC, 12, PAL_MODE_ALTERNATE(12));
   palSetPadMode(GPIOD, 2, PAL_MODE_ALTERNATE(12));
and then waiting on connection.
I'm tested my device with stm32fcube and work good.
Re: STM32F429 and sdcard
That demo is done to run on a F407. There are differences in the board files and configuration files.
You don't provide sufficient info for a suggestion.
vahid4134
Post by vahid4134 »
I just use main.c functions. I use stm32f429 configuration file.
I checked with gdb and my program waiting on
//ChibiOS/os/hal/ports/STM32/LLD/SDIOv1/sdc_lld.c:574
while (((sta = sdcp->sdio->STA) & (SDIO_STA_CMDREND | SDIO_STA_CTIMEOUT |
                                     SDIO_STA_CCRCFAIL)) == 0)
There are two possible causes:
1) Clocks to SDIO.
2) Pins setup (or wrong board file).
Please verify settings in one of those board files that have SDIO.
vahid4134
Post by vahid4134 »
Thank you for response and sorry Im begginer in Chibios.
My hardware with stm32fcube work good.
I attach my code. Please check my code
I dont know why waiting in connection.
this is my bt of gdb
#0  0x0800185e in sdc_lld_send_cmd_short_crc (sdcp=sdcp@entry=0x20000a04 <SDCD1>, cmd=cmd@entry=16 '\020', arg=arg@entry=512, resp=0x20000798, resp@entry=0x200007b0)
    at ../../../os/hal/ports/STM32/LLD/SDIOv1/sdc_lld.c:574
#1  0x08000bd8 in sdcConnect (sdcp=sdcp@entry=0x20000a04 <SDCD1>) at ../../../os/hal/src/sdc.c:711
#2  0x080022d8 in main () at main.c:89
RT-STM32F429-DISCOVERY.zip
(10.94 KiB) Downloaded 228 times
vahid4134
Post by vahid4134 »
I changed PIN setup in board.h and finally work.
Thank you
