ChibiStudio Preview 14, OpenOCD config selection problem
Posted: Mon Dec 14, 2015 10:07 am
Hi Giovanni!
I have stumbled upon a problem when I was updating to Preview 14.
Now when the debug is launched, the box for selecting the OpenOCD configuration does not open, and hence the debug fails as it does not know which Target it is.
How can I fix this? Is this an error on my side?
I tried to debug with the supplied examples, and it did not work there either.
Best Regards
Emil Fresk
Error:
Best Regards
Emil Fresk
Error:
symbol-file C:\\ChibiStudio\\chibios3\\testhal\\STM32\\STM32F4xx\\USB_CDC\\build\\ch.elf
Reading symbols from C:\ChibiStudio\chibios3\testhal\STM32\STM32F4xx\USB_CDC\build\ch.elf...done.
set remotetimeout 20
monitor reset init
"monitor" command not supported by this target.
monitor sleep 50
load C:\\ChibiStudio\\chibios3\\testhal\\STM32\\STM32F4xx\\USB_CDC\\build\\ch.elf
You can't do that when your target is `None'
tbreak main
Cannot access memory at address 0x8009d82
continue
The program is not being run.
kill
