[INFO] Preparing for 16.1.0 release
Posted: Sat Jan 02, 2016 11:54 am
I think this is a good moment for a new release, most changes are in the HAL so there are no worries about RT and NIL. Please, if you think that there is something still to be fixed before release post here ASAP.
To developers, please make sure that the various ports (including those in community repo) are ready and aligned to the the latest code, if you need more time please post here. Please make sure to align all xxxconf.h files to the latest version too.
Note that I decided for a different development cycle. I wish to have faster releases, so in future we will focus on one major feature per release in order to not destabilize the code base. No more stable/unstable cycles. Point Releases will be marked by <year>.<month>.<patch>.
So far we have:
*** ChibiOS 16.1.0 Release Notes.                                          ***
ChibiOS 16.1.0 is composed of several independent but inter-operable
sub-projects: RT, NIL, HAL.
*** ChibiOS 16.1.0 highlighs ****
This release has been developed with focus mainly on the HAL subsystem and
general STM32 support. RT and NIL received minor bug fixes that have also
been back-ported to previous stable branches.
*** ChibiOS 16.1.0 general improvements ***
- ChibiOS release version number redefined as <year>.<month>.<patch> in order
  to not confuse release version numbers with products version numbers.
- Improved ARMCMx GCC rules.ld supporting multiple RAM regions. It is now
  possible to assign stacks, data, bss, etc ot any of the defined RAM regions.
  - Added capability to allocate initialized, zeroed and not initialized data
    to any of the defined RAM regions.
*** What's new in RT 3.1.0 ***
- Added new function chVTGetTimersStateI() returning the state of the
  timers list. This is useful to assess if it is convenient to transition
  to lower power modes.
- Added CodeWarrior compiler support to the e200 port.
- Minor bugs fixed.
*** What's new in HAL 4.0.0 ***
- New watchdog (WDG) driver.
- Added support for STM32L0xx, STM32L4xx, STM32F7xx, STM32F446, STM32F030xC,
  STM32F070x6, STM32F070xB, STM32F091xC, STM32F098xx devices.
- Improved USB driver.
  - Modified the driver to have a separate USB_SUSPENDED state, this
    allows the application to detect if the USB is communicating or if
    it is disconnected or powered down.
  - Added synchronous API.
  - Removed queued API.
  - Improved USB support for STM32 USBv1, OTGv1.
  - Isochronous support for STM32 USBv1, OTGv1.
  - STM32 USBv1/OTGv1 buffers and queues do not more require to be aligned in
    position and size.
- Improved Serial-USB driver.
  - New buffers queue object.
  - Modified the driver to reject write/read attempts if the
    underlying USB is not in active state. In case of disconnection the
    SDU driver broadcasts a CHN_DISCONNECTED event.
- Improved CAN driver.
  - Better errors reporting for STM32 CANv1.
- Improved UART driver.
- Improved PAL driver.
  - Added "lines" handling to PAL driver, lines are identifiers of both
    ports and pins encoded in a single value. Added a set of macros
    operating on lines.
  - Added GPIOv3 driver for STM32L4xx.
- I2S support added for STM32 SPIv2 peripheral.
- Board files an demos for STM32 Nucleo32 boards.
- Added latest CMSIS headers for all STM32 families.
- STM32 DMA drivers have been unified and consolidated in DMAv1 and DMAv2.
  - DMA channels selection now supported on all devices with the new mux
    mechanism.
- Added serial driver support for USART 3..6 on STM32F030xC devices.
- Added support for differential mode to the STM32F3xx ADC driver.
- STM32 GPT, ICU and PWM driver enhancements. Now it is possible to
  suppress default ISRs by defining STM32_TIMx_SUPPRESS_ISR.
  The application is now able to define custom handlers if required
  or simply save space if the driver callbacks are not used.
  Now the functions xxx_lld_serve_interrupts() have global scope, this
  way custom ISRs can call them from outside the driver module.
- Added TIM units use cross-check in STM32 GPT, ICU, PWM and ST drivers,
  now use collisions are explicitly reported.
- Added support for I2C3 and I2C4 to the STM32 I2Cv2 I2C driver.
- Added support for SPI4...SPI6 to the STM32 SPIv2 SPI driver.
- Added support for UART4...UART8 to the STM32 UARTv2 UART driver.
- Added support for UART7 and UART8,LPUART1 to the STM32 UARTv2 serial
  driver.
- New STM32 ADCv3 driver supporting middle STM32 devices (F3, L4).
- New STM32 ADCv2 driver supporting large STM32 devices (F2, F4, F7).
- New STM32 ADCv1 driver supporting small STM32 devices (F0, L0).
- Introduced support for TIM21 and TIM22 in STM32 ST driver.
*** What's new in NIL 1.1.0 ***
- Minor bugs fixed.
Please post if you wish something added to the notes.
In the meanwhile I will proceed with release-related quality steps.
Re: [INFO] Preparing for 16.1.0 release
Posted: Wed Jan 06, 2016 11:03 am
by Korken
Hi Giovanni!
Is there any migration guide to follow, or just have a look at the current state of the HAL and use that as reference?
I will port my extended ICU and the extended PWM drivers for STM32 to follow the latest version.
Best Regards
Emil
Posted: Wed Jan 06, 2016 11:07 am
It will be exactly the same code we have in trunk now. Migration will be easy from 3.0, unlike all the trouble we had from 2.6->3.0.
I am completing the reports, probably it will happen later today.
Posted: Thu Jan 07, 2016 10:24 am
by Korken
Perfect!
Posted: Sat Jan 09, 2016 8:49 pm
by alan5
I'm just curious what counts as a release under the new naming scheme, or are they now independent?
E.g. one feature focused on per <year>, <month>, or other?
Posted: Sat Jan 09, 2016 9:14 pm
It is very simple, no more stable and unstable releases but major point releases every 4..8 months. The version number is <year>.<month>.<patch>. The patch number increases for small bug-fixes-only releases that can happen also at short intervals.
Within a release RT, NIL and HAL will have their own version numbers like usual: <major>.<minor>.<patch>.
I don't want huge gaps like the one happened between 2.6 and 3.0, changes will be very focused and finalized to the next release. Big changes will happen in separate branches and not stop the normal development in trunk.
